stitchly
June 26, 2011, 12:53 pm
I have an intermittent starting issue with my Focus.
Sometimes it fires first turn of the key.The next time it might take 2 or 3 turns and then now and again it turns over but wont start.
Plenty of life in the battery and when it dosent start a bump down a hill does the trick.
Otherwise its running perfect.
Any suggestions? Before I have to take it to Ford and part with a shitload of dosh!
H3lly
June 26, 2011, 2:52 pm
Do you hear the starter crank each time?
stitchly
June 26, 2011, 3:32 pm
It cranks but just dosent fire.As I said sometimes it starts first crank sometimes it takes 2 or 3 cranks but after 10 or so I give up and resort to bumping it!
June 27, 2011, 4:54 am
If it cranks but wont fire, sounds like a starter brush issue, does the car run perfectly fine when you bump it?
stitchly
June 27, 2011, 10:01 am
After bumping goes fine!
June 27, 2011, 11:01 am
Could be a duff starter or starter brushes then fuel keeps going timing keeps the engine spinning, check coils and plugs but i suspect you will replace the starter...
