Full Version: car won't stop
Ford Owners Club - Ford Forums > United Kingdom - General Ford Discussions by Model > Ford C-Max Club
pcw
having arrived home I turned the ignition off in the normal way but the car would not stop. In the end I had to stall the car and disconnect the battery. Now it will not start.
Any idea's?
c-maxxer
What model / engine is your car ? Diesel ?
pcw
[quote name='pcw' post='8269' date='Dec 9 2008, 09:22 PM']having arrived home I turned the ignition off in the normal way but the car would not stop. In the end I had to stall the car and disconnect the battery. Now it will not start.
Any idea's?[/quote]
1.8 Petrol
maccyski
I had this problem!!!!!!!!
Car switched off fine, then hour later the headlights wipers and radio turned on, started engine, everything reset, turned engine off, got out, locked car, then realised my engine was still running!!!
Its to do with the brake lights. water had got in one of the rear brake lights (cant remember which one) and played around with the electrics.
Did the engine stop when you pressed the brake pedal?
Full Colour Version: car won't stop
