daddy5times
June 30, 2011, 7:57 am
hiya chaps it seems my aircon isnt working ? when i turn it on the little light near the button lights but nothing else no change in revs or noise nothing can any1 help ? maybe its a fuse relay ifso witch 1 is for aircon thx in advance any help appreciated
btmaldon
June 30, 2011, 8:33 am
Most likely it has lost its gas. If there is not enough pressure in the system, it will not operate.
How old is the car? You may get away with a top up, or you may have a leak in the system.
daddy5times
June 30, 2011, 9:29 am
01 plate 1.8 duratec would nt i still hear compressor?
btmaldon
June 30, 2011, 9:37 am
[quote name='daddy5times' timestamp='1309444159' post='134113']
No. If there is not enough pressure in the system, it will not activate it.
My Mk 3 Mondeo had a leak due to a pipe to the compressor rubbing on part of the chassis, until it developed a hole.
When was the last time you used the aircon, as it is supposed to be used regularly (even in winter) to stop the seals drying out and cracking?
