emmajc
July 13, 2011, 2:01 pm
Hi,i bought myself what i thought was a bargain a couple of days ago.
Its a 2001 focus 1.8 16v zetec,but it seems to have a couple of issues which have only been noticed after a couple of days of driving.
Firstly,when i start the car it seems to idle fine for around 5 seconds,then it clicks,idles rough then clicks again,or cuts out impossible when at traffic lights as it dies.engine also gets very hot very quick.
also on 2 occasions i have been driving along when the steering has gone really hard and all the lights on the dash come on,even though its still running..
CONFUSED !!
Any help would be much appreciated
thanks
July 13, 2011, 2:05 pm
[quote name='emmajc' timestamp='1310583660' post='135824']
CONFUSED !!
thanks
the steering is either a power steering pump fault or a steering rack issue the dying at lights is either idle control valve or start the car up open the hood and look at the throttle look behind it at the firewall and youll see a rubber hose coming from the rear of the throttle see if it collapses when the cars revved or idling if so replace it what do yoiu mean the engine gets hot quick? does the temp gauge sit half way? are both the top and bottom rad hoses hot and the radiator when left idling
emmajc
July 13, 2011, 2:16 pm
[quote name='artscot79' timestamp='1310583906' post='135826']
The temp gauge goes just past halfway as soon as i start the car,not sure if its supposed to sit that high straight away ?.
The rubber hose doesnt collapse when left to idle(for the short time it idles before cutting out) or when revved.the top and bottom hoses and the rad get hot quite quickly.
thanks for the advice re the steering,i'll get it looked at.
July 13, 2011, 2:23 pm
[quote name='emmajc' timestamp='1310584615' post='135827']
temp gauge shouldnt go up that far straight away i think you should get a ford diagnostics done it sounds like the temperature sensor at the back of the head is faulty this can explain why its cutting out that sensor shows the temp on the gauge but is linked to the ecu and calculates fueling if its showing a hot engine when its actally cold it will be running lean it wont be cheap as the alternator needs removed just to get into it but it does need done or it will damage the engine.
emmajc
July 13, 2011, 2:28 pm
[quote name='artscot79' timestamp='1310585018' post='135829']
Thanks,i'll get it booked in for diagnostic asap.hopefully its nothing too serious..
cheers for the advice.
Engine Trouble !
