MARLEY
July 22, 2011, 12:34 pm
Hi All
My focus 2.0l tdci is really strugling to start once it is warm, if i keep ignition key turned it will eventually run.I have checked all pipes and fittings etc and all seems ok, the only other thing it does is hesitate on tickover every 5 seconds or so.
Any help or advice will be appreciated
Thanks in advance
Paul
Stalybridge
johnH
July 22, 2011, 12:52 pm
i would check your fuel filter, easiest and cheapest place to start.
MARLEY
July 22, 2011, 12:56 pm
[quote name='johnH' timestamp='1311357165' post='136978']
I have already changed fuel filter and made no difference, its one of those annoying little problems which will eventually get sorted
July 22, 2011, 1:12 pm
crankshaft sensor?
MARLEY
July 22, 2011, 2:16 pm
[quote name='stef123' timestamp='1311358357' post='136981']
crankshaft sensor?
thanks for reply
where is it located and can it be tested ??
July 22, 2011, 2:51 pm
[quote name='MARLEY' timestamp='1311362217' post='136989']
thanks for reply
Its located where the gearbox meets the engine, it picks up a signal from the flywheel.
Not entirely sure if it can be tested though im afraid.
MARLEY
July 22, 2011, 3:16 pm
[quote name='stef123' timestamp='1311364301' post='136994']
will have a look in morning, hopefully no rain,
if it is faulty will it cause problems starting ??
i was thinking a fuel problem.
a quick test would be to swap sensors with another focus.
Regards
Paul
July 22, 2011, 4:07 pm
[quote name='MARLEY' timestamp='1311365780' post='136997']
Regards
Paul
I've not heard of many problems with them on the focus but certainly other cars, and causing poor running when the sensor gets hot - starts breaking down
certainly swapping the sensor or getting one from a breakers yard would help.
MARLEY
July 22, 2011, 4:53 pm
I have just done the test where you hold the set button in and turn ignition on, everything is fine with no codes,
ps does anybody know where my EGR VALVE is located 2007 2.0l tdci ???
thanks
Paul
July 24, 2011, 4:15 am
if im right, its at the back of the engine block closest to the cabin.
MARLEY
July 24, 2011, 4:18 am
[quote name='jeebowhite' timestamp='1311498929' post='137157']
thanks for reply.
will get up on ramps and have a look,
will let you know how i get on
Paul
Bad Starter
