chriskelly
August 16, 2011, 12:01 pm
[quote name='paramaniac' timestamp='1313072179' post='139526']
I would also add that if you are going by the MPG on the trip computer, this isn't very accurate. If you want to know what MPG you are really doing, then do this next time you fill up:
[list]
[*]Fill the tank up to the point where the fuel pump clicks off.
[*]Zero your odometer.
[*]Next time you fill up, make sure you fill up to the same point where the fuel pump clicks off.
[*]Make a note of the amount of fuel you have just put in.
[*]Make a note of the mileage on your odometer.
[*]Use the number of litres and mileage to work out your MPG: http://www.mpg-calculator.co.uk/
[/list]
I have a 2009 1.8 petrol and get about 30-35mpg, I don't drive particularly slowly or economically. I might see if Ford will update the PCM firmware on mine as it's still under warranty.
I will need to work out to see how different it really is so just need to top up
Isnt it amazing how much we rely on computers and alarms to give us even the simples of information...
Thanks for your coments
