Yesheadjon
August 5, 2011, 9:18 am
Hello,
I'm new here so my apologies if this has been covered. I did search first. I have a problem that the carpet in the drivers side foot wells (both front and back but not in between) are soaking wet. only the base of he footwells is soaked (i.e. not the part that goes up the side to the plastic trim and there is no sign of any water around the doors. I have tried putting the hose on the doors but that does not seem to be the issue.
Are there any known issues where something gets bunged up that might cause this?
Any help would be much appreciated.
Jon
Gabor01
August 10, 2011, 12:52 pm
Hi Jon,
I have the same (similar) problem in my 1 year old Mondeo: the base of the footwells is soaked in front and rear on the right side (in my case it's the passenger side). The cause was identified in a Ford garage: the pipe for the condensed water outlet of the A/C unit is cracked and the water leaks towards inside when the A/C is on, especially in wet/humid weather. The broken pipe will be changed next week, hope that will solve the problem. (It's still covered by the warranty.) I was told that the same 'phenomenon' may also happen if this pipe is simply blocked eg. by dead insects, etc.
Since 2 days I don't use the A/C (just in ventilation mode, ie. 'A/C Off'). Now the carpet is almost dry: after picked up most of the water by a dry/wet vacuum cleaner, it's not becoming more humid again. This way you may verify if your problem is really connected to the condensed water from the A/C unit. Once the problem is fixed, make sure to dry the fleece mat also below the soundproofing foam in the front footwell.
Hope the description of my case will also help to solve the problem of your car.
Good luck!
Gabor
(from Hungary)
