oilburner
August 7, 2011, 2:59 am
Does anyone know if the one touch up/down function can be switched on for all windows on a EB Titanium.
All the switches have the 2 click just only works on the driver door
cheers
Steve
August 8, 2011, 4:17 am
Could be the ECU that needs this switching on, but if it clicks twice, it should set the motor off, dont even think it runs through the ECU though...
Do you actually feel it click twice?
oilburner
August 8, 2011, 11:50 am
all four switches click twice but only the driver side works for one touch
focus steve77
August 8, 2011, 12:28 pm
Heard that you have to change the relay behind the door panel that controls the window motor, to the same as the drivers as thats what controls 1 touch so all other doors have to have the same relay..... not looked into it enough myself yet though....
oilburner
August 10, 2011, 10:47 am
is there any way of getting a wiring diagram for the car - that should have the answer
August 12, 2011, 7:32 am
You could find one on google, some people on here have found specific wiring diagrams but not sure I have seen a full car one
jocojohn
August 14, 2011, 4:19 am
Hi, you may have found your answer now but I've just had the same problem on a 2002 Focus after disconnecting the battery..
The windows need to be 're-taught', you need to go round each window in turn and hold the 'up' side of the button (2nd click) until the window is all the way up, then press and hold 'up' again 3 times, for around a second each, repeat for each window. If one-touch down does not work, repeat, but in the 'down' direction
Hope this helps
cuke
August 14, 2011, 4:55 am
Hi, it isn't quite the same process to program the windows on the 2011 Focus as the previous models:
1. Lift and hold the switch until the
window is fully closed.
2. Release the switch.
3. Lift the switch again for one more
second.
4. Push and hold the switch until the
window is fully open.
5. Release the switch.
6. Lift and hold the switch until the
7. Open the window and try to close it
automatically.
8. Reset and repeat procedure if the
window does not close automatically.
Chris
oilburner
August 28, 2011, 12:08 pm
Chris
just picked up your reply up.
all windows now programed and work on one touch and global open/close
many thanks much appreciated
tomo2001
September 4, 2011, 9:37 am
[quote name='oilburner' timestamp='1314551311' post='141817']
Chris
Can anyone check this with engine running vs switched off. Just programmed mine as previously one touch worked with engine switched off but didn't work with engine running (had to hold switches).
