carlos84
August 12, 2011, 4:25 pm
anyone care to shed some light on my little problemo? the heaters on my 2003 zetec will only work on full blast (setting number 4) nothing else on 1 to 3. help.
August 12, 2011, 4:28 pm
[quote name='carlos84' timestamp='1313184330' post='139823']
If the dial is working then i would suggest that there is a fault with the resistor for the motor.
http://www.fordpartsuk.com/shop/ford_focus_heater_resistor_1299.htm
johnH
August 12, 2011, 6:01 pm
sounds like as stef123 says....resistor pack for the blowers
jocojohn
August 14, 2011, 4:09 am
Yes, you need a new resistor pack. Setting 4 bypasses the resistor pack totally, which is why that setting works. I've had this problem on both my Focuses
blueovalcraig
August 14, 2011, 7:39 am
One quick fix is to remove the resistor and solder a wire onto each end of the little diode.
