Hello there first post so here goes, have a 1999 finesse estate td. Been running ok but lacking power in lower gears. Now struggling in lower gears and lacking power. Had trouble starting and checked fuel lines, found no fuel delivery, so primed the pump and it started and ran ok. Having the same problem restarting needing to re prime the pump.
So before I start replacing things myself is there a quick guide to finding the solution to the problem. I have used Haynes manuals in the past to trouble shoot and end up replacing parts that I did'nt need. So hopefully I can be pointed in the right direction before I go to the garage.
Cheers Mike
