ronnie2345
August 14, 2011, 11:16 am
i have owned my 51 plate mondeo tddi for a week it has run with out any problems untill yesterday when i was driveing it started jumping and there was lots of white smoke and then cut out. i took return pipe off filter it was empty if i fill it up it will start then cut out when it is empty then not start again untill i fill filter i have tryed changeing the filter but there is no diffrance any ideas would great thanks
August 14, 2011, 1:53 pm
you could have a problem with the lift pump or the power supply to it,check the fuse and relay for the pump and see if there is power at the pump itself.
ronnie2345
August 15, 2011, 5:05 am
[quote name='mintalkin' timestamp='1313348008' post='140028']
thanks a will try that today
