hi
having recently brought my car (mk3 ghia estate 03)the parking sensor alarm is constantly sounding when in reverse is there anything i can check or replace before i take it in to a ford garage to correct this? thanks for your time.
cyb
August 16, 2011, 3:57 am
sounds like you may have a faulty sensor. Is it possible for you to disconnect one sensor at a time to work out which if any is causing the problem?
snowster
August 16, 2011, 9:48 am
have tried that disconnected each in turn still no change thanks for the advice though
August 16, 2011, 9:54 am
this may help
http://parking-sensor.co.uk/troubleshooting.asp
snowster
August 16, 2011, 10:27 am
[quote name='mintalkin' timestamp='1313506488' post='140287']
this may help
thanks mate have tried that but still emitting one continuous tone when in reverse
cyb
August 17, 2011, 3:07 am
[quote name='snowster' timestamp='1313506084' post='140285']
then I guess the only other advice I can give is...
"go forward in life and all your problems will be behind you"
