puggers
August 24, 2011, 2:28 pm
Hi
I have an S Max 2.0 Titanium diesel which I am looking to sell but it has a fault which I need to sort first. We recently replaced one of the rear brake lamps after being warned it was faulty by the dash board computer thingummy.
We have checked that the bulb is working correctly etc but we can't seem to stop the faulty warning sensor flashing up every time you start the car up and then use the brakes.
What do we have to do to get rid of this warning? There doesn't seem to be anything to reset anywhere?
August 25, 2011, 2:36 am
double check both bulbs, and replace the other if you havent already done so, also take a look at the housing / fixture and make sure that there is no corrosion or bad connections to the bulb holder. this could be a part of the issue.
natz89
August 25, 2011, 7:48 am
Hi, your best bet is doing what the guy said above but also getting a multimtere and testing the wires from the fixture make sure theres no faulty wires or trapped ones in the dash. =)
puggers
August 25, 2011, 11:08 am
Hi. Thanks for help. Tried another new bulb, system working perfectly now, although with old new bulb, the lights worked perfectly but the warning display was still showing on dash. Suspect very sensitive system. Thanks again.
