bazz61
August 29, 2011, 3:50 pm
Hi can anybody help my 06 mondeo lx petrol auto has just started to play up.
Engine revs really high on idle, I've noticed a buzzing sound by the throttle,sounds electrical buzzing stops when i rev the engine. Other than that engine is running fine. Thanks
natz89
August 29, 2011, 4:04 pm
[quote name='bazz61' timestamp='1314651010' post='141964']
Hey bazz, ive just had probs with my fiesta and revving probs and i got told it was the idle vavle. I removed it today, cleaned it with carb cleaner and it works a treat...you mite wna try it. Other to that check the sensors are all on correctly...mainly your mass air flow sensor.
goodluck
Nat
bazz61
August 29, 2011, 4:12 pm
Cheers for that Nat i'l give it a go.
natz89
August 30, 2011, 4:49 am
[quote name='bazz61' timestamp='1314652331' post='141972']
No worries =) let me know how it goes
bazz61
September 10, 2011, 4:21 am
cleaned idle valve still had the problem.friend done a diagnostic check error code p0122,Changed the throttle position sensor no change. engine still revving hard
bazz61
September 10, 2011, 4:49 am
[quote name='natz89' timestamp='1314697789' post='142004']
Hi nat cleaned idle valve still had the problem.friend done a diagnostic check error code p0122,Changed the throttle position sensor no change. engine still revving hard
September 10, 2011, 4:53 am
[quote name='bazz61' timestamp='1315648185' post='143548']
was it just a code reader your friend used? a live data diagnostic tool would let you see what the TPS is reading when you press the pedal.
is the wiring to the sensor ok?
bazz61
September 10, 2011, 5:03 am
Don't know what sort of reader it was,will ask when i see him,Going out now to have a quick look at the wiring to sensor.
bazz61
September 10, 2011, 5:08 am
Ive noticed that the TPS makes a buzzing sound when i turn the key to ignition, then goes off when i turn the throttle then goes back on when i release the throttle, is this normal
