Full Version: Reversing Lights Not Working
oilcan
bulbs ok,but feed wire is dead.Tested connector on gearbox switch no power either wire.tested fuse (no.80) behind glove box,ok====but when I tried my test light on the fusebox connectors that the fuse connects with they were also dead.Ignition is switched on and in reverse gear.I need help!!!!!!
relay ?
oilcan
[quote name='mintalkin' timestamp='1315068246' post='142663']
relay ?
Thanks for reply,never thought about a relay.Have you any idea where the relay is?Thanks
[quote name='oilcan' timestamp='1315159379' post='142805']
Should be in the engine compartment Fuse Box, lift the bonnet, small rectangular box close to the battery,
also under the lid should display a diagram of each relay and its purpose :)
oilcan
Thanks to all for info on reversing lights,but today I think my turbo is on its way out,so reversing lights on hold Thanks Bill
Tori
Its the reverse light switch im the gearbox. Part is 17 quid from ford, they are a weak part and do go. I had mine replaced last week xx
MrGoatsmilk
I changed the reverse light switch a while back, couldn't find an how to anywhere so put something together. Hope it helps anyone who's looking at changing the part.
http://youtu.be/L7KNcLaVYSY
[url="http://youtu.be/L7KNcLaVYSY"]Reverse light switch video [/url]
Stu
Full Colour Version: Reversing Lights Not Working
