September 10, 2011, 4:53 pm
[quote name='Broxson' timestamp='1315675868' post='143601']
Could you possibly tell me where the pollen filter is located as Ive read it may have become damp which is giving off the smell ?
[font="Calibri"][size="3"]According to the Haynes manual, the pollen filter should be changed every 12,000 Miles [/size][/font]
[font="Calibri"][size="3"]1. Release the 2 fasteners and remove the trim panel above the passenger’s side footwell [/size][/font]
[font="Calibri"][size="3"]2. Remove the glove box[/size][/font]
[font="Calibri"][size="3"]3. Undo the 2 fasteners securing the fuse box/central junction box/GEM, then lift it from the mounting bracket on the bulkhead. [/size][/font]
[font="Calibri"][size="3"]Move the fuse box/module to one side; there is no need to disconnect the wiring plugs.
[/size][/font]
[font="Calibri"][size="3"]4. Release the clips securing the wiring harness to the fuse box/module mounting bracket, then undo the 2 nuts and remove the bracket.[/size][/font]
[font="Calibri"][size="3"]5. On models with air conditioning, undo the retaining bolt and remove the cool air pipe from the heater housing to the side of the glove box.[/size][/font]
[font="Calibri"][size="3"]6. Disconnect the wiring plugs from the recirculation flap motor and heater motor blower resistor.[/size][/font]
[font="Calibri"][size="3"]7. Undo the 3 bolts, remove the cover and gently pull the filter from the housing.[/size][/font]
[font="Calibri"][size="3"]8. Fit the new Pollen Filter using a reversal of the removal procedure, ensuring that the filter is fitted with the airflow arrows pointing straight back in to the cabin.[/size][/font]
[font="Calibri"][size="3"]That’s word for word what the Haynes says, [/size][/font]
[font="Calibri"][size="3"]Now for my input,[/size][/font]
[font="Calibri"][size="3"]Id also remove the bulb from the glove box as it gets fairly hot if left on for a long period, just don’t forget to put it back in, also id get a cup or something to store all the screws in the one spot, and finally from experience when putting the glove box back in place ensure the bottom left part is tuct in correctly as you won’t realise it’s not until all the screws are back in and you try to close it, [/size][/font]
[font="Calibri"][size="3"]Then you realise it doesn’t and you have to unscrew it all again, so just check the bottom left part of the box is in correctly prior to screwing it back.[/size][/font]
[font="Calibri"][size="3"]Hope this helps mate.
[img]http://i575.photobucket.com/albums/ss192/lennymanwoods/Image0807.jpg[/img][/size][/font]
[font="Calibri"][size="3"] [/size][/font]
