[font=Calibri][size=4][b][i]Just purchased a set of Heated Mist Type Water Jets found on the New 2011 Focus.
From Paynes Of Hinckley[/i][/b][/size][/font]
[font=Calibri][size=4][b][i]To Purchase the Heated Version £2.93 each exc. P&P Part Number: 1708797 [/i][/b][/size][url="http://www.ebay.co.uk/itm/220849176475?ru=http%3A%2F%2Fwww.ebay.co.uk%3A80%2Fsch%2Fi.html%3F_nkw%3D220849176475%26_sacat%3D0%26_dmpt%3DUK_CarsParts_Vehicles_CarParts_SM%26_odkw%3Dford%2Bjets%26_osacat%3D0%26_trksid%3Dp3286.c0.m270.l1313%26_fvi%3D1&_rdc=1"][size=4][b][i]Click Here [/i][/b][/size][/url][size=4][b][i]Top Seller 100%[/i][/b][/size][/font]
[font=Calibri][size=4][b][i]To Purchase the [u]NON[/u] Heated Version Part Number: 1708796 [url="http://stores.ebay.co.uk/paynespartsshop?_trksid=p4340.l2563"]Click Here [/url]to Contact Seller
Or Contact your Local Ford Dealership to Purchase.[/i][/b][/size][/font]
[u][font=Calibri][b][i][size=2][color=#008000]Please Note: If you are unsure that you Ford has or has not got heated jets, purchase the heated version and when fitting the jets, if your system is not heated just tape the electrical plug to the water hose, the system will work just the same.[/color][/size][/i][/b][/font][/u]
[size=3][b][color=#FF0000][font=Calibri]So time to get fitting [img]http://www.fordownersclub.com/forums/public/style_emoticons/default/smile.gif[/img] [/font][/color][/b][/size]
[font=Calibri][size=4][b][i]Lift the bonnet on your ford, and ensue the ignition is off, and keys out of the car,
[img]http://i575.photobucket.com/albums/ss192/lennymanwoods/Image0906.jpg[/img][/i][/b][/size][/font]
[font=Calibri][size=4][b][i]Begin to unclip the eleven clips that hold the bonnet insulation pad in place simply squeeze the two sides in towards each other and gently pull outwards then store them neatly together. Preferably cut a plastic bottle in half or an empty Pringles tin to store them all in, until required for re-fitting, this type of temporary storage is good practice for working on your car, as if one is lost this type of part can be a nightmare to replace,
[img]http://i575.photobucket.com/albums/ss192/lennymanwoods/Image0908.jpg[/img]
[img]http://i575.photobucket.com/albums/ss192/lennymanwoods/Image0909.jpg[/img][/i][/b][/size][/font]
[font=Calibri][size=4][b][i]Once all clips are removed gently flap the pad down towards the engine and gently pull out away from the car in a straight line,
[img]http://i575.photobucket.com/albums/ss192/lennymanwoods/Image0910.jpg[/img]
GOT A SHOCK TO SEE BAD FORD PRINTED UNDER THERE [img]http://www.fordownersclub.com/forums/public/style_emoticons/default/blink.gif[/img] IS mine a Reject [img]http://www.fordownersclub.com/forums/public/style_emoticons/default/ohmy.gif[/img] [/i][/b][/size][/font]
[font=Calibri][size=4][b][i]Store this Insulation part preferably in a vertical position, indoors away from wind, and any risk of it being stood on during the change over process,
[img]http://i575.photobucket.com/albums/ss192/lennymanwoods/Image0913.jpg[/img][/i][/b][/size][/font]
[font=Calibri][size=4][b][i]Once this is out of the way, unplug the water hose from the bottom of the current jets, by giving a gentle tug, the pipe should pop off and a small amount of water is expected,
[img]http://i575.photobucket.com/albums/ss192/lennymanwoods/Image0918.jpg[/img][/i][/b][/size][/font]
[font=Calibri][size=4][b][i]Then to remove the electrical connector use a flat screwdriver to lift the clip and slide the connector out from the socket,
[img]http://i575.photobucket.com/albums/ss192/lennymanwoods/Image0919.jpg[/img]
[img]http://i575.photobucket.com/albums/ss192/lennymanwoods/Image0920.jpg[/img][/i][/b][/size][/font]
[img]http://i575.photobucket.com/albums/ss192/lennymanwoods/Image0922.jpg[/img]
[img]http://i575.photobucket.com/albums/ss192/lennymanwoods/Image0923.jpg[/img]
[font=Calibri][size=4][b][i]Finally as seen in the picture below, press the clip on the jet in towards the pipe and push upward to the top surface of the bonnet, the jet should pop out of place, gently remove and replace with the new type,
Continued on Next Post Below.....[/i][/b][/size][/font]
