Full Version: 2006 Focus Tdci 2.0 Whining Noise
daniel2011
hi all, i have a focus 2.0 tdci 2006 covered 47.000 miles, just today i found a fault, there is whiring/whining sound comeing from the timing belt/ alternator area, it seems the noise is more from the timing belt, but the noise only occurs when i apply revs to the engine otherwise it is sweet as a nut, there has been no warning lights on or the performance of the car has not been effected, could this be the cam belt adjustors being to tight putting extra pressure on the bearings, could this be the problem.
if anyone could shed some light on this please it would be much appreciated
many thanks dan
sizak
you will need to replace the auxillary belt tensioner for a spring loaded one(a ford odification).you will have to change the belt also as i think the one currently fitted is a stretchy belt type.you will need the new 3 bolts that hold the new tensioner onto the head as they are longer.
daniel2011
[quote name='sizak' timestamp='1317555469' post='146674']
thanks very much, i will have a look into this hope it works, fingers crossed.
ooops
Hi all,
Ive got a 2.0 tdci 2006, same whining noise from car when accelerator depressed.
anyone got any info on this yet?
cheers
paul.
daniel2011
[quote name='ooops' timestamp='1318826946' post='148811']
Hi all,
cheers
paul.
hi i had my alternator changed this solved the problem bit pricey though £370 including there stupid diognostic test lol but today i have another problem it wouldnt start, but the AA seem to think i need a new battery as it is the original, also they think that the alternator can f**k the battery up when it all goes wrong becuase of some smart charge system these engines have, hope this has helped thanks.
