andthen
October 1, 2011, 3:02 pm
Hi there fellow mondy owner
I have a zetec spec model with various titanium extra's included...
one of which is the convers+ display system.
The car came with the ford rds 6006 with a aux in port in the glove box but no USB port. if the car was fitted with the sony dab unit it would have a USB port in the glove box...the sony , convers+ and steering wheel controls all work as one and work operate a USB device..
it is unusual for the zetec to be fitted with the convers+ , so my question is??..
is there a hidden USB port somewhere in the convers unit where i can plug a USB toggle stick , because the USB port that would of being in the glove box must plug into something????
from what picture's of the sony dab unit i have found online , there does not appear to be a USB port on it , front or rear.
if you are now completely confussed please sit down and have as stiff drink on me..
October 1, 2011, 3:11 pm
[quote name='andthen' timestamp='1317499348' post='146602']
Welcome to the forum,
when you get a momment join photobucket and upload some pics of your motor,
then copy the URL address from the pics and paste them in your post on here so we can see it.
Id love a stiff drink,
instead im stuck at home on a saturday night with the laptop,
have you checked in the centre console mate?
and also are your footwell lights working or do you know about them ?
andthen
October 1, 2011, 3:30 pm
cheers chap ,
i will get some pics on here soon....
i trying to get some solid info before i set lose with the screwdriver;-)
i once blew a fuse box up in an orion years ago , so my good lady isn't as enthusiastic as me about taking the car apart:-))
Engine Chris
January 7, 2012, 1:00 pm
My Titanium X (60 plate about 5 minutes before they fitted the daytime running lamps) has the Sony DAB Radio and only has an AUX 3.5mm audio jack in the glove compartment. i was hoping for the USB too - but I could only find mention of that in the radio that has the Sat Nav built in...
Works great with my daughter's iPod touch, where #7 on the volume is deafening, but my Samsung Galaxy S2 needs to have the radio cranked above 20 to get decent sound. V annoying!
Hope this helps...
Chris
incidentally, I'm impressed with the DAB, but I'm sure in FM mode Sony have made it sound crap on purpose!
andthen
January 8, 2012, 2:31 am
Hi Chris
I found a few answers to this subject in the s-max section . There is a subject on there titled convers+ , lots of information and one users reply was most interesting........
To implement the USB port you need to upgrade the bluetooth module in the car to the later version & buy the additional wiring looms.
The USB wires to the bluetooth module, which in turn wires to the radio headunit.
You also need a radio with a sufficient firmware version to support the new bluetooth module & USB connection....end quote
I haven't tryed this myself yet but instead of using the aux port the play music you can use the cars bluetooth to play tunes of a iphone/other smart phone maybe?? .my friend does this on his s-max which has alot in common with our mondeos
cheers amigo ;-)
snowjunkie
January 16, 2012, 5:51 pm
Hi
I have a 2010 Mondeo Titanium X and had the same issue, Even though advertised in the spec I only had a 3.5mm aux with the sony head unit and the USB was blanked out, However bluetooth worked with my Iphone 4. sales staff at fors garage useless. asked a guy in the Parts dept for a sloution. He kindly told me that the USB plug is part of the standard wiring loom and as such is behind the glove box. The USB socket was £2.70. I removed the glove box and found the USB plug neatly plugged into a blanked point on the left side of the glove box. I cut out the blank clipped in the USB and attached the plug. Connectede my Iphone and perfect now I have integrated Iphone.
Hope this helps.
kingy54
January 19, 2012, 4:06 am
[quote name='snowjunkie' timestamp='1326757873' post='161688']
Hi
Hope this helps.
Many Thanks for that i have a Zetec mk 4 estate and going to see if wiring i behind the glove box...Hope SO
andthen
January 29, 2012, 5:05 am
Back to this one again guys.
Mike glad you found that out , I have just taken the glove box out and sure enough there was a blanked out plug on the left side with three wires into a six port plug , is this similar to the one in yours chap??
so next it is to fords for the plug
happy days ;-)
Charlie119
January 30, 2012, 3:14 pm
This forum has been extremely helpful. I have a fird mondeo titanium 59 plate. My Sony 6 cd player often says 'unknown' when someone calls me on my phone through BT. Checked my iPhone and it's not that. After some searching found I might need to update my radio. But Ford website says thrust can do this through USB port. In my Car i can inly find an AUX point. After looking at this helpful thread I pulled out the glove box and found a 6 pin plug. So then I contacted Ford online to ask them where I could buy a USB port from to attach to this. They said they make no such part?! But when I read above a couple of people said they have brought the USB port, so could I ask where you brought it from.
Thanks for your help
steffbratt
July 27, 2012, 2:46 pm
I to am after this USB part. I have been told by a number of poeple that its around the £2.70 mark so assuming it must exist. But were from?
scousey boy
September 20, 2012, 11:48 am
Has anyone got a part number for this usb loom that is ment to be £2.70? Ive been to me local ford parts and they were no help at all! and insisted it doesnt exsist. Any help on this would be great!
Andymagee
October 21, 2012, 10:22 am
I have. I will put it on when i get home.
StuBob
October 22, 2012, 6:57 am
You guys have really got me interested, I too have only the aux port in the glovebox - or so I thought!
So presumably if I get the 6 pin to USB adaptor and then the usb/jack cable (£8.99 from amazon) to iPod cable I would have complete control over my iPod from the steering wheel.
Where can you buy the USB to 6 pin adaptor and what is the part number if anyone knows it?
Thanks - in eager anticipation
Stuart
Andymagee
October 22, 2012, 1:25 pm
Usb Connection from Ford part number 1543450
Bezel to make it tidy 1550778
Good luck
Quiggles
February 6, 2013, 6:20 am
Hi
Realise I'm replying to an old topic now - but I bought the USB connection 1543450 and the back of it looks like you plug in a female USB cable and not the 6 pin plug I have exposed from the side of the glovebox. So I appear to be short a piece of wiring or adapter - any thoughts?
Also bought that bezel and can't work out where that would snap in?
help?!
Alpha TD
February 11, 2013, 10:50 am
Hi Quiggles, The lead you found on the left hand side of the glove box is a rouge lead for some other use no one at Ford can figure out. I just sent my USB port back due to the wrong config. You need to do what it states earlier and that is too upgrade your stereo and BT module then you can attach a loom to the plug. I havent done this as i'm gonna look for another way.
Quiggles
February 11, 2013, 10:56 am
Probably bad form to reference other forums, and I apologise for that, but I have included the link so the appropriate people are credited...
I did more research myself - the rogue cable appears to be something to do with the passenger airbag but the full story seems to be:-
[quote]
[font=Tahoma][size=3]www.fordmondeo.org/forum/printpost.php?tid/807994/[/size][/font]
[color=#000000][font=Tahoma][size=1][color=#212121][font=Arial, Helvetica, sans-serif][size=3]Behind the glove box you will find the main wiring harness.[/size][/font][/color][/size][/font][/color]
[color=#000000][font=Tahoma][size=1][color=#212121][font=Arial, Helvetica, sans-serif][size=3]On pre 08/2008 Mondeo's (fitted with BT/VT) there was an 8 pin socket and a plug looped wires to control the microphone wiring (6000/Sony or satnav).[/size][/font][/color]
[color=#212121][font=Arial, Helvetica, sans-serif][size=3]On post 08/2008 Mondeo's (BT/VC now fitted as standard) there is a 22 pin socket and plug with looped wires, this varies the AUX socket wirng for BT/VC only (aux direct to stereo) or BT/VC+USB (aux to BT/VC module, stereo output from BT/VC module to stereo).[/size][/font][/color]
[color=#212121][font=Arial, Helvetica, sans-serif][size=3]Therefore AUX socket in glove box has 3 wires.[/size][/font][/color]
[color=#212121][font=Arial, Helvetica, sans-serif][size=3]If you can find a Ford dealer who knows how to upgrade the software on a BT/VC only module (later 19G488 with usb socket), you would only need to get :-[/size][/font][/color]
[color=#212121][font=Arial, Helvetica, sans-serif][size=3]Cable Assembly 1543691 £20.14 Cable from the BVC to the USB Socket[/size][/font][/color]
[color=#212121][font=Arial, Helvetica, sans-serif][size=3]Control AS 1543450 £3.15 USB Socket[/size][/font][/color]
[color=#212121][font=Arial, Helvetica, sans-serif][size=3]Bezel 1540778 £5.55 Plate to mount USB in glove box[/size][/font][/color]
[color=#212121][font=Arial, Helvetica, sans-serif][size=3]Otherwise you will need a 19C112 module as well.[/size][/font][/color]
[color=#212121][font=Arial, Helvetica, sans-serif][size=3]Unfortunately I cannot post any pictures of the above socket, or it's exact position as my Mondeo was a 12/2007 build without BT/VC.[/size][/font][/color]
[color=#212121][font=Arial, Helvetica, sans-serif][size=3][u]PLEASE NOTE[/u][/size][/font][/color][/size][/font][/color]
[color=#212121][font=Arial, Helvetica, sans-serif][size=3]The date the wiring changed is given as 08/2008 by Ford, but any car built within a month or so of this date should be visualy checked (to confirm wiring)before ordering any parts.[/size][/font][/color][/quote]
