Flis45
October 3, 2011, 9:06 am
We had a windscreen replacement co round to replace the front screen on our Mk 1 Focus, which has Quick Clear. The guy said that the bolt used to earth it was missing, and we would need to get one before he could reconnect it properly. It is located under the plastic housing containing the courtesy light, which they replace, because apparently they often break. So he was reluctant to fit the screen and then fix the Quick Clear later.
Does anyone know what this should be, and if possible a part number for it?
Thanks!
Parf
October 7, 2011, 4:46 am
I have a similar problem on my MK2. The quick clear wasnt working and when i checked a new screen had been fitted and the person who fitted it didnt even connect the cables. I connected the right and left connector but it still does work. The fuses are fine and the relay clicks when the button is pressed. Is there an earth somewhere that also needs connecting?
sjwred
October 9, 2011, 5:38 am
[quote name='Parf' timestamp='1317980786' post='147412']
Check inside the left and right connecters coming from the loom (not the w/s ones) see if they are clean and not a corroded blue colour,if you can get hold of an electrical reader see if you have power going to to those leads,the TDC strap(gold strap) is indeed above the courtesy light,that connection must be clean and tight ,if loose it an spark and could cause a fire,on the newer Foucus like mine 2002 model there is 1 connecter at the centre down the bottom of the w.s and 1 by the courtesy light. The engine HAS to be running to get the heated w/s to work
sjwred
October 9, 2011, 5:52 am
[quote name='Flis45' timestamp='1317650765' post='146890']
Thanks!
I hope it's just missing and not snapped off,ring any ford dealer explain where the bolt is and that should do it.the courtesy light comes off quite easy ,use a torch to see if bolt is missing or broken off,tuck earth strap away from any metal surface until it's fixed. If bolt is snapped off it will need to be drilled out and re-tapped I suggest by a garage.
Parf
October 10, 2011, 3:46 am
Thanks for the advice sjwred. I just tried to remove the courtesy light and it doesnt want ot move. I dont want to force it incase i snap something. The housing appears to be screwed but i cant get to the screws without removing the light cluster.
Parf
October 10, 2011, 4:14 am
Finally got it out and you were right sjwred the earth connection was there. The idiot who fitted the new screen didnt bother connecting it, the old one was still attached and had been cut to get the old screen out. The new screen earth strapped was just tucked in by the headlining. Ive connected it all up now, including the power by the wipers as they didnt even bother connecting them up either. All i need now is a cold morning so i can test it.
Thanks for all your help.
sjwred
October 10, 2011, 9:50 am
[quote name='Parf' timestamp='1318238043' post='147744']
sjwred
October 10, 2011, 9:54 am
You can test it b4 it gets cold. Turn on heated w/s with engine running turn off blowers, the revs should drop a little as it uses a lot of engine power
Wait for 1-2 minutes touch the outside of the w/s near the black band and then touch the centre of drivers and passenger side with a flat hand, you should feel the difference
Parf
October 11, 2011, 8:10 am
Looks like its finally working. There is a difference in temperature around the window.
Thanks for all help guys.
