Preee
October 16, 2011, 4:35 pm
Start from the bottom using flat screwdriver covered with a soft duster , then move to each heater control doing the same while appling slight pulling pressure with other hand , you will feel each clip pull out , only when you have released the center clips by heater controls then move to 3/4 way up , one clip each side , last clips then are at the top , do it gently and it comes off nice and easy
the part around the cup holder and gear stick does not come off it is melted together , you remove you have to start and remove screws from armrest , unclip under handbrake , remove bottom of cup holder there is a screw under there, silver surround around gear stick pops off where you will then see 2 more screws holding it all together
