Full Version: 2010 Tdci Brake Upgrade ?
poshpawsfiesta
hiya does anybody know if focus st front disk and pads will fit on a 1.6 tdci zetec ? im in need of a bit more stoping force :)
[quote name='poshpawsfiesta' timestamp='1319214130' post='149413']
the st brakes will be bigger so you will need the bigger calipers and carriers. im looking at getting the focus st front calipers for mine, i think they are 320mm compared to the 300mm as standard on mine and some models of focus.
james_60
Hi Poshpaws
Why not convert the rear drum system to disc brakes
Jamie
[quote name='james_60' timestamp='1319221126' post='149433']
Hi Poshpaws
Jamie
thats a good idea, i done that with my mk1 focus. braking power is exactly the same but they take much more of a pounding under hard breaking. quite an expensive mod but it looked good
poshpawsfiesta
hmm i was thinking about coverting rear drums to disks but i was thinking i would have to put new brake lines in + abs and traction control sensors etc ? wich would all cost alot and apparently rear brakes are only there to balance out the braking force not do do all that much pysical breaking.
whereas the focus is now coming up to 30,000 miles so the front disks and pads need replacing anyway, i was hoping it would be a quick and easy chage over.
but if its going to be alot of hastle id just stay standard.
we used to have a 2009 2.0 tdci titanium wich had rear disks and bigger fronts and that was much better, with a less spongey brake pedal.
james_60
Hi posh
Why would you need new brake lines.
The handbrake is cable operated
The brakes utilise the existing hydralic cable
Abs operates on the back wheels as well (i could be wrong dont bite me)
Fitting bigger fronts is a piece of cake just make sure they fit inside the existing alloy wheel
Jamie :-)
fitting rear discs is a bit of work, you will need to change the handbrake cable as you will need one with the fittings for the calipers.
the brake hoses will probably be a different length (was on my mk1)
hopefully the abs sensors would come with the hubs for the rear
have you got 280mm front discs? the 2.0 tdci probably had the 300mm discs
poshpawsfiesta
[quote name='james_60' timestamp='1319272058' post='149495']
Hi posh
Jamie :-)
Just because i thought drums and disk's used a diffrent sort of brake line. (Bearing in mind im only guessing.)
I think ure find drums are not powerful enough to lock up completly, or there isnt enough braking force sent to them to make them lock up.
Got my mate do an emergency stop in the wet in front of me and the abs looked like it only kicked in on the front wheels. (its quite visable.)
Also im pretty sure the ESP dosent use the rear drums as when u would try and do a scandinavian flick in the 2.0 tdci titanium the back would not slip out atall (its got rear disks) but the 1.6 tdci with only drums at the rear does, not that i do this all the time, but at the end of my road there's a massive turning around circle and i tried it there as i am very interested on how these systems work.
poshpawsfiesta
[quote name='stef123' timestamp='1319276249' post='149503']
hmm i dont know the sizes, on ford parts uk its dosent say the sizes but they look the same infact the ST disks are cheaper, but the st pads look alot more meatier, think im going to have to research this a bit longer before i order them.
normall front disks> http://www.fordpartsuk.com/shop/ford_focus_2008_front_brake_discs_2253.htm
st front disks> http://www.fordpartsuk.com/shop/ford_focus_2008_st_front_brake_discs_2251.htm
normall front pads> http://www.fordpartsuk.com/shop/ford_focus_2008_front_brake_pads_set_2254.htm
st front pads> http://www.fordpartsuk.com/shop/ford_focus_2008st_front_brake_pads_set_2252.htm
Focus ST discs - Disc Diameter 320.0mm Disc Thickness 25.0mm
Focus 1.8/2.0 diesel - Disc Diameter 300.0mm Disc Thickness 25.0mm
focus petrol - Disc Diameter 278.0mm Disc Thickness 25.0mm
[url="http://www.brakepartssuperstore.org.uk/index.html"]all info from here[/url]
Full Colour Version: 2010 Tdci Brake Upgrade ?
