Full Version: Focus 2005 Remote Keyfob Fault
ian andrews
Hi.
Just joined the club & this is my 1st post :)
I've got a 2005 (new shape) Focus Zetec with a fault.
The keyfob stopped operating the central locking but works ok using the key (locks & unlocks all doors & boot from drivers door).
I replaced keyfob battery & checked all fuses, all ok but still not working. Also no DTC's stored. I decided to disconnect the battery to see if it would reset & on re-connecting battery, all buttons work fine on the keyfob until the ignition is turned on then it ceases to work again. If the battery is disconnected & re-connected, same again - all working fine until ignition turned on.
Anyone got any ideas what may be causing this..?
Thanks, Ian.
Nigel S
This may be the GEM. If so it is a Ford dealer job only.
ian andrews
Hi.
Thanks for the reply Nigel.
Is it a case of replacement or can they be reprogrammed..?
alz
Hi Ian and welcome to the forum
Just pop into a ford dealers and have them check your remote key, to see if is working, you can get a repair kit for the key off e-bay for less than £20. to fix the buttons, if it is working reprograme it to the car, turn on off about six times untill it sounds two times, then press any button on the remote..
Alan
have a look at this link of e-bay [url="http://www.ebay.co.uk/itm/Ford-Mondeo-Puma-Escort-Focus-RS-ST-3-Button-New-Remote-Alarm-Key-Fob-Repair-Kit-/160667634187?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2568898a0b"]http://www.ebay.co.u...=item2568898a0b[/url]
ian andrews
Hi Alan.
Thanks for the info, very interesting & handy to know that replacement fobs are available :)
I wouldn't have thought it is the fob as it works everytime until the ignition is switched on & I don't think the ignition will affect the fob - although I'm not 100% certain & stand to be corrected.
I rang BBA Reman today to see if they had any info about the GEM, they don't do replacements at present & didn't have any info.
Found some more info here & going to have a look round the fusebox area & check all the connections as soon as I get the chance:
http://passionford.com/forum/ford-focus-rs/322061-gem-wont-go-into-learning-mode.html
Not holding out much hope though as disconnecting & re-connecting the battery & turning ignition on doesn't really point to a bad connection but prob worth a look.
alz
Hi Ian Just looked at your post again, did you do a full set, disconnect the battery, turn ignition on, then reconnect the battery, also have your radio code to hand.
alz
Ian if nothing works, I think a trip to ford is needed, and get them to plug to there computer, and see if they can find out what is wrong..
ian andrews
Hi Alan.
Thanks for your replies.
I've got radio code so no worries there :)
Do I need to turn ignition on while the battery is disconnected..?
I wouldn't have thought it's recommended to re-connect battry with ignition on in case of a voltage surge or spike..??
I may have to take it to the dealer if I can't resolve it.
if you disconnect the battery, all your doing is taking the remaining charge of electric that is in the cables and moving it to completely drain everything, then when the car looks dead, leave for 15 minutes dead, and then reconnect the battery up, its a cold hearted kick up the a*se for your car, but can do wonders :)
as the IT crowd say, turn it off, turn it on again! - just dont do what jeb did, in jebs jobs... :rolleyes:
alz
turn ignition on just before you connect the battery, have done this on mine with no problems.
or you could try this frist.
Full Colour Version: Focus 2005 Remote Keyfob Fault
