Full Version: Regen Problums
cheb
hi i got a ford focus 1.6 tdci
i fill up the additive tank (next to the fuel tank) with the right stuff
took my car to fords to get it regen, but they are tellling me that the tank if empty.
then someone else told me its the wrong additive i put in witch i know is bullshit,
they said they cant regen it as its a sencor, at a cost of 472, and 350 for the addtive
DOES ANYONE KNOW WHERE I CAN GET SENCORS FROM CHEAPER THAN FORD
AS ANYONE HAD THE SAME PROBLUM AS THIS THANKS ROB
catch
[quote name='cheb' timestamp='1319727730' post='150182']
sounds to me like they are attempting to dick you, FRF Motors up the road from you in Swansea, it's a Volvo dealers, But Volvo was owned by Ford when your motor was built, they share many parts, and definitely engines, they will defo sell you the additive hundreds cheaper than that. As to the sensor well can you trust the garage you went to, what's it's part number.......I'd go else where for a second opinion.
Look there is a guy over on the Volvo forum goes by the forum moniker of Rufe, but real name is Simon works in their parts department, forum members including myself swear by him, dead helpful wither you buy through him or not, defo give you a price on the additive.
[url="http://www.volvoforums.org.uk/showthread.php?t=57125"]Simons Link[/url]
cheb
thanks for the info mate
will give that simon at frf a call and see what he as to say
see if he can shed some light on this
thanks rob
[quote name='cheb' timestamp='1319740616' post='150223']
thanks rob
these dpfs are now on watchdog, cars not regenerating as they should dpfs failing early now manufacturers are telling people if you drive short distances buy a petrol lol. the expert said to regen naturally you need to drive at a high rev ie 2500 rpm constantly for 15 mins so dont drive in 5th drive in 4th instead but if you stop or slow down you have to start the regen all over again
catch
[quote name='artscot79' timestamp='1319792372' post='150278']
Now so there is no misunderstanding in regard to the above quote:
This does not mean to say easing off at a roundabout or because someone pulls out in front of you. No what is meant by that is, if you reach your destination before the regeneration process has concluded, which in all takes about 15 minutes once the exhaust gasses are up to temperature. Same goes for if you end up in slow moving traffic for the duration of the process. You see it's all about the exhaust temperature gasses being high enough to trigger the process, and burn off the soot that has built up in the DPF.
Rule of thumb is, if all you use your car for is knocking about on short cold engine journeys, then buy a petrol engined car. (school run, local supermarket) But if you clock up decent mileage every three hundred miles or so with journey times circa 20 to 30 minutes. Then the car should undertake a "passive regeneration" of the DPF as per normal if and when required.
If you not do such journeys as the norm, then sell the car and get a petrol one, or take it for a burn up the local bypass circa every 300 miles of usage.
[i]
To Conclude[/i].
No need to get the jitters about DPF's understanding you have one and what you need to do is all that is required. We had a Volvo S40 2.0D SE with a DPF (same engine as fitted in the 2.0TDCi Focus and Mondeo) It used to go weeks just plodding 1.75 miles through town rush hour traffic on a cold engine in a morning, and the reverse journey in the early evening. Had it nine months and it never ailed a thing, not so much as a burp out of the DPF, because I knew what it required every 300 mile or so.
In the nine months of our ownership it covered 5,368 mile only. 2,560 miles in three trips to Dorset, Scotland and Devon, the other 2,808 miles where split between town driving and trips to towns or shopping centres no more than 15 miles away. So you see you can live with a DPF easily if you know what your doing.
Most people who come a cropper with DPF fitted cars, the one needing a DPF replacement every 75k/ 6 years and additive top ups very 37.5k /3 years. Are the people who buy [in ignorance] 4/5/6 year old cars that have not had the top ups or replacements done, or are due for doing. And the present owner does not want to bear the rip of fees charged by main dealers to undertake such work, so they shut it to the trade and it's moved on to an unsuspecting new owner.
[quote name='catch' timestamp='1319795791' post='150287']
[i]
To Conclude[/i].
actually the expert did say that the rpm must be above 2500 for 15 mins if you stop or slow down the revs are not high enough and therefore the regen process cuts off and will have to be started again as it requires continous driving to complete the process they had tested a few cars and found stopping at lights or slowing in traffic switched the regen process off
cheb
thanks for all the info
just to update
went to get my car from fords today (car was driving fine just had engine light on)
after all the bull they told me got in the car and left, and guess what the car as gone into limp mode
i went back and played hell cos it was driving fine when i took it there, now they tell me that i got to pay 170 to find out why the car wont regen
and thats before i know whats wrong with the car, i wish i know about all this stuff before i had the car, i would of got 1.8 or 2.0 instead,i will keep u all posted as to what happens I BET IT WILLL COME BACK THE FILTER NEEDS CHANGING LOL
catch
[quote name='artscot79' timestamp='1319823257' post='150348']
Not dissing what your saying Artscot, but I find that totally stupid, who would design a system like that, it's in all probability a software programming issue. As the regen criteria is length of time and exhaust gas temperature, or so I was led to believe. I slow to enter a roundabout, exit a roundabout and continue bombing down the dual carriage way Aire Vally Trunk Road come on.
[b]And if that was the case how come I never had any DPF trouble with the driving conditions our car was doing for all of the 9 months we had it, baring the 19 days it was bombing down to the south coast [2 x 8 days] and a 3 day jaunt up to Lanark in Scotland....answer me that[/b] ;)
im no expert this was from the expert on watchdog apparently they have tested it and dispute the manufacturers way that the regen works they found that as soon as the revs dropped too low and the car stopped the regen process stops also thats why manufacturers tell you to maintain a constant speed and drive down a motorway noy round townsome cars now need 30 mins to regen many people on atchdog are complaining about it and being missold cars all manufacturers stated if you do short trips or town driving you should be advised against buying a diesel and get a petrol
catch
It was this weeks watchdog wasn't it.
It was on but I was doing something else at the time.......DPF issues....old story as far as I personally was concerned so was not watching or listening intently.......might re watch it on BBC iPlayer
Art I did not mean I was expecting you to answer my rhetorical question, hence I put a wink smiley at the end of it. It was just my way of disputing what they had said with my real life driving experience.
james_60
Hi Folks
I think we all need to calm down here. :ph34r:
We are doing what people did when catytic converters came in around 92-93 (not me as i was only 7-8) :ph34r:
Just Drive the car. Keep it well maintained. B)
I know i was fussed about what type of dpf i had but now iam like shrugging my shoulders and just getting on driving the car. :rolleyes:
Jamie
[quote name='james_60' timestamp='1319964583' post='150532']
Hi Folks
Jamie
just a nice discussion to be honest no arguing or disputing simply sharing opinions. its those who worry about the big bill and the fact they feel ripped off that we discuss this topic
james_60
hi artscot
I just flicked through the manual for my car and it only has a short piece on dpf filters.
According to the manual page 121 on the owners handbook (the version i have on the back of the book is ADA04/10 which must be the revision number)
It States
[size="3"][u]Diesel Particulate Filter (DPF)
[/u][/size]
The DPF forms part of the emissions reductions systems fitted to your vehicle. It filters harmful diesel particulates (soot) from the exhaust gas.
Regeneration
Do not park or idle your vehicle over dry leaves, dry grass or other cumbustible materials. The DPF regeneration process creates very high exhaust gas temperatures and the exhaust will radiate a considerable amount
of heat during and after the DPF regeneration.
And After you have switched the engine off.
This is a potential fire hazard.
[u][size="4"]Caution[/size][/u]
Avoid Running out of fuel
Note After you have switched off your engine the fans may continue to run for a short period of time.
Unlike a normal filter which requires periodic replacement, the DPF has been designed to regenerate, or clean itself to maintain operating efficiency.
The regeneration process takes place automatically. However, some driving conditions mean that you may need to support the regeneration process.
If you drive only short distances or your journeys contain frequent stopping and starting. where there is increased acceleration and deceleration, occasional trips with the following conditions could assist the regeneration process:[list][*]Drive your vehicle at a constant speed, preferebly on a main road or motorway, for up to 20 minutes.[*][*]Avoid prolong idling and always observe speed limits and road conditions.[*][*]Do not switch off the ignition.[*][*]Use a lower gear than normalto maintain a higher engine speed during this journey, where appropriate.[*][/list]
This was taken from the 04/10 version of the users manual.
My car with help from the forum has a Coated DPF which requires no fluid whatsoever and is a for life filter
This is because my car is a Stage V 109ps 1.6 TDCI engine. If your Car is a Stage IV car then it will be fitted with a Different type of DPF where in which a additive tank will have been installed next to the fuel tank and you will need the
additive tank topping up with fluid at the 37500 mile service (correct me if iam wrong)
The DPF Forms part of the exhaust system. When the DPF fails it is usally around 75k miles or longer depending on how it is driven A NEW DPF will be required (Aftermarket or OEM)
I Hope You Will Find This Helpful Let Me Know Your Thoughts And Vote This Post Up If You Do
Jamie :-)
Chutney
Can I ask a quick question?
When you are referring to Stage IV and Stage V cars are you referring to Euro IV and Euro V cars or something else?
I have just put a deposit down on a 2008 1.6 TDCi Style (110 DPF) with 44k on the clock so would be interested in finding out whether the car has a need for the top up or not.
Having looked at it, I think it is the revision of the last shape (if that makes sense) ie. the one with the chrome tipped front grill and revised (clear) rear lights.
Collection won't be a few weeks, so accessing the owners manual is a bit of a no-no at the moment. I do however have the chassis number, if there are any clues to be gained from that?
catch
[quote name='Chutney' timestamp='1320094507' post='150730']
When you are referring to Stage IV and Stage V cars are you referring to Euro IV and Euro V cars[/quote]
yes
[quote]I have just put a deposit down on a 2008 1.6 TDCi Style (110 DPF) with 44k on the clock so would be interested in finding out whether the car has a need for the top up or not.
Well according to Fords Maintenance Schedule the Eloy's additive reservoir [which your car has] should be refilled at it's third annual and every sixth year service and so one or every 37.5k whichever comes first. The car in question being on 44k, well I doubt in all honesty that it will have been done. Lets be fair if you were moving your motor on after three years ownership, you would not pay for a service prior to selling it. Nor would you spend the additional £150 or more that dealers are asking to refill the additive reservoir and the ECU reset.
If I were you having it done would be part of the deal, and I'd want a stamp on the log book stating it had been done prior to you taking delivery of the car. Research the cost of "Forced Regenerations" or replacement Filters and you will understand why I'm telling you it's important that it is known to have been done.
Read link in my sig relating to DPF's.
Forget the £1,000 service quoted in the opening post on the linked to thread, peeps on here have recently had quotes of over £1,500 for DPF replacement.
Chutney
[quote name='catch' timestamp='1320106386' post='150762']
yes
Cheers for the reply. I am buying the car from a car supermarket (not Carcraft) so will have to investigate what has been done already, though I doubt there is any wriggle-room to get them to do it, as they operate a very strict policy on negotiations (ie they just don't do it) so it may have to be something I get done as soon as I collect it.
However, other than it being recorded in the log book, is there any visible checks an owner can do to check whether it has already been topped up?
I apologise for all the questions, I have been reading up on what I can find out, but searching on my phone isn't the easiest thing to do.
catch
[quote name='Chutney' timestamp='1320132248' post='150769']
though I doubt there is any wriggle-room to get them to do it, as they operate a very strict policy on negotiations (ie they just don't do it) so it may have to be something I get done as soon as I collect it.[/quote]
That old chestnut....everybody deals if they want my trade, I even haggle in the likes of Comet only been refused it once, the salesman was young and inexperenced. He missed a sale, and like I said to him no worries I'll buy it cheaper elsewhere on line ...which I did. Me personally I'd be walking away from the deal, but obviously you money is your money.
[quote]However, other than it being recorded in the log book, is there any visible checks an owner can do to check whether it has already been topped up?
In all reality I would say no.
When I had my Volvo you could go into any Volvo dealer give them your reg number and they could look up it's service history on their system. Now wither you can with Fords I don't know, but a quick call to a Ford dealers would answer that particular question for you, and possibly the one wither it has been done or not. And on top of that if it was found not to have been done you could get a quote for the 3 year major service, plus the Eloys top up and reset charge. That way you would know how much this deal is going to cost you in real terms.....
You can appear to be getting a good deal at some dealers only because your getting a motor that is not being sold to you with the relevant Ford services having been done.
Chutney
I did manage to squeeze a deal, but I did have to really push very very hard... Not that I am afraid to do so, as again I also haggle pretty much on anything/everything.
Bit of a pity that there is no way of checking as there was no specific mention of it in the car's paperwork at the garage (think the salesman was a bit worried when I was waiting outside the door waiting for them to open this morning - which is always a good thing when they will have already sent off the V5 for my reg-plate transfer ;) as the outcome of me defaulting on the final deal would leave them out of pocket).
I also got the details of the garage who did the 3rd year service (@37,200 miles) and am planning to ring them at lucnch and see if they had done it.
I also popped into the Ford Main Dealers round the corner this morning and asked about electronic service records, but it was a nope. However the service manager did say they could/would do a bleed and replace of the DPF fluid for £92 (all inclusive) for me.
The manager there also said that the cars should have enough fluid to do an extra 5-10k miles over the 37.5k service spell, but the car would just throw an EML fault code when it ran out anyway and he would recommend just waiting until that happened (hmmm... Not my way)
Also he said that changing the DPF was an expensive job and realistically they expect them to survive well past the 75k mark if the fluids are maintained and the car driven properly. Again it would be a matter of just replacing the DPF when it fails, rather than 'because it it is due'.
The car was however a very good deal and having had cars from them before reassures me somewhat.
As catch has said, there are things to be wary of, you need to be forearmed why buy a car for 2500 when its going to cost you an extra 1500 or 2000 to get the fluid and dpf done, when you could walk away and buy on for 3500 all done, and all cared for. Its your choice what you want to do, but i would say, althought you like the 'focus' do you like 'that car' or could you spend a little more time and visit a few other retailers and maybe get the model you want but a better deal???
Its ultimately your decision, remember you have time to cancel the deal as a cooling off period is always available subject to 'reasonable use' and theres no more reasonable use than not collecting your car!
As for the dpf, your right to ask questions, i made the first and final mistake of buying without researching my focus and its dpf, had i known a fraction of what i do now (thanks to those on this forum and specifically catch!) i would have been following my advice at the time of buying :)
Chutney
Agreed.
Being doing more research into the DPF scenarios and also what other options are available to me. The car I have put a deposit on looks to be absolutely bang on, other than the one question over the DPF.
The bonus for me, I suppose, is that I do a fair amount of motorway miles which should hopefully mean lots of chances for the DPF to go through passive regenerations, rather than having to rely on the car choosing to do an active regeneration and being blocked from doing it due to driving conditions.
Again, I have plenty of time to consider my options, but I also do wonder whether the dreaded DPF problems are as commonplace as it would appear - as forums ALWAYS focus on the negatives and can make a reasonable problem sound like a much bigger one. Not that I am saying that this is the case here, but I would be interested to know what the actual failure rate is as a proportion of the volume of cars sold is.
I have also come from owning a 9yo Vauxhall VX220 with 70k+ miles on the clock so having to maintain a car is not really a new scenario to me (and that has a dedicated 'what to look out for' webpage with a list as long as your arm... But is simply the best peice of machinery I have ever had the pleasure of seeing / using).
catch
oh you flatter me Jeeb, :rolleyes:
Chutney, like I said in my [b]conclusions[/b] in post five on this thread
[quote]
No need to get the jitters about DPF's understanding you have one and what you need to do is all that is required.[/quote]
And yes we know Fords build into their maintenance schedules a safe margin prior to component failure. Naturally they don't expect vehicles to be falling over three years and two months into year four, or failing DPF's in week eight of it's seventh year......We know of peeps on here getting circa 85/95k out of their DPF's before they fail.
But the fact is your at/near when certain expenditure regards the DPF should have been spent or is due to be spent, and we are just making you aware of that fact.
Some people stretch to get a nice car, and unfortunately in some cases a couple of months down the road, they are stood at a main dealer service desk being told they need to spend £200 to £1,600 on DPF issues. And as a result feel robbed and gutted......if only they had know is all they can say to themselves.......
Chutney
All feedback is being greatfully received and if it isn't vomit across that way then I apologise.
As once said a knowledgeable man is a wise man and should be followed. Ignorance is dangerous.
catch
[quote name='Chutney' timestamp='1320257914' post='150969']
Chutney,
You've nothing to apologise for, if your happy with the car then go for it. I dare say the next car I get may well be another diesel, as even on our low mileage, we should save circa £500 a year in fuel and road tax.
james_60
did anyone read my post i mean i actualy bothered to take the time to read the manual ? I did want some feedback
Jamie
[quote name='james_60' timestamp='1320316839' post='151107']
Jamie
apologies we get carried away ive heard of people getting stuff from these guys Chester Exhausts on 01244 372555there are 2 types of additive One is the Adblue (Urea) that reduces the Nitric Oxides and the other is Cerenium (III) Oxide that is mixed directly with the fuel and lowers the oxidisation temperature of the soot (Diesel Particulates) so that the DPF can get hot enough to reburn them which one ford uses is anyones guess but you may find a volvo dealer or pugeot will have the same stuff cheaper i read my mates manual and it doesnt give specific info on the additive.
i found this on ebay http://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=m570.l2736&_nkw=Eolys+fluid
Peugeot/Citroen also use eloys 176 which usally costs between €130-150 for 3 litres. allegedly this is the same as ford cost incl service and reset ecu is more than 200 hopefully this is of some use to you mate
Catch - what can I say - I love you!! lol
Its true though, most of my knowledge originated from the forums, and I remember you were a keen participant in the various DPF threads I have raised, amongst a few others, and the forums are a good place to learn, and to get the right advise from those who have learned the hardware (that would be me!) and those who just have a clue from day one... (that would be 90% of the rest of the forum, lol)
Chutney, just do what is best for you, as you have the time to do so, use it wisely and make sure that you are falling for the car that suits you and will please your wallet... my bank manager hated me after I bought my Focus, and had I had the availability of a bit more time to research, I would have still gone with the Focus, but maybe a petrol, or one that the DPF wasnt going to be a nuisance on... Or I would have moved house - maybe that would have helped! lol
Jamie, your research was bang on, the details are right, and as long as you trust the manual and act accordingly, then you can save a lot of hassle... as for the details arts provided I think that should be everything, lol OEM is only important as long as the warranty is valid. after that point, look after it, make it last, but when it goes... why give all your money back to Ford? they wont reward you (no dealers will really) and you could save an arm and a leg with perfectly good aftermarkets...
A lesson well learned from someone who got burned by this topic!
catch
[quote name='jeebowhite' timestamp='1320332992' post='151150']
it's reciprocal :D
And james_60 as your last post/question was directed to all thread participants.....yes I did read your quotes from your manual. And I thought that's good of James to copy all that info down, but I did not realise you wanted an accolade for doing it ;):P
I myself can write pieces on a thread subject that some on here may consider boarder on challenging Leo Tolstoy's epic War and Peace :rolleyes: And some posts even appear to become the grave stone that marks the end of a threads interesting life............but as I'm not "needy" I don't take it personally :D
But in all seriousness, as the post in question was directed to artscot79 ...............I reckon he owes you a box of chocolates or possibly an oil filter as an act of contrition.
And Chutney, jeebo is right, he bought a motor he thought was the "dogs whatsits" ...............I mean come on who doesn't. You don't go to a dealers look at a motor and think I reckon I could have a load of hassle with that motor but I'll buy it anyway. As it turned out it was the spawn of Satan.
james_60
Hi dudes
Thanks for the replies.
Iam glad we have finally sorted out what cars have the non maintenance dpf's and the eloys fluid type.
Can we make a sticky for people who want to know if there car has what type of dpf we have discussed.
I just wish there was some indication whether the dpf was regenerating for piece of mind.
I will always try and help people before i help myself lol
We should arrange a meet up
Jamie :rolleyes:
catch
[quote name='james_60' timestamp='1320396433' post='151247']
Hi dudes
Can we make a sticky for people who want to know if there car has what type of dpf we have discussed.[/quote]
Yes that was indeed a step in the right direction James, and like I said, that being the case I may consider a euro 5 designated 1.6TDCi when I eventually swop [I like the bigger boot on the Mk2.5, and you know what I'm still not fully sold on the exterior styling of the Mk3. Though I don't doubt it is a more technically superior car]
[quote]
Yes that would be a good move, that way peeps would know not to stop the car until they got a message saying regen successful.
[Quote='Catch']
And Chutney, jeebo is right, he bought a motor he thought was the "dogs whatsits" ...............I mean come on who doesn't. You don't go to a dealers look at a motor and think I reckon I could have a load of hassle with that motor but I'll buy it anyway. As it turned out it was the spawn of Satan. [/Quote]
Lol oh so very very true... Its good to have the information first though, looking at new cars can be all too exciting, but thinking about them can be the last thing on anyones mind!
As I have previously mentioned (not necessarily this thread... or was it?)... I think Ford should make an "uh oh - you just cabbaged your DPF" light, and maybe they should have a "dont panic - its regenerating, its working - keep up the good driving and I will look after the DPF" light... Personally I think they would be very advantageous. but unfortunately the only way to know that its doing it right, is to drive each day and add another tally mark against your "no limp home mode" chart.
PS, if anyone here owns the car reg NG55 HXO please do let me know, and I will probably advise you to run!! that is if Satan hasnt recalled it in a puff of smoke, a blaze of fiery glory, and the biggest fireworks display ever seen by mans naked eye.... all because its DPF is having a bad day...
catch
[quote name='jeebowhite' timestamp='1320416531' post='151281']
looking at new cars can be all too exciting, but thinking about them can be the last thing on anyones mind![/quote]
Spot on there mate.....I've been guilty as charged on more than one occasion.
[quote]PS, if anyone here owns the car reg NG55 HXO please do let me know, and I will probably advise you to run!! that is if Satan hasnt recalled it in a puff of smoke, a blaze of fiery glory, and the biggest fireworks display ever seen by mans naked eye.... all because its DPF is having a bad day...
Like I said when you parted company with it, the next owner will probably undertake tens of thousands of miles in it and it wont even have missed a beat...................and so it shouldn't the amount of parts it had replaced on it! :blink:
Chutney
Intriguing that the regen process is not advised to drivers when, as suggested, it would really make sense to do so.
Again... I was certainly not insinuating that anyone would be so dumb as to knowingly buy a car that they thought was dodgy either.
I would be intrigued to know whether there are physical conditions that can be monitored on (or around) the DPF that could be used to log regeneration activity. I know a chap who has been digging into the supposedly impenetrable Lotus ABS unit and Z22SE trying to see how they tick to enable the former's deletion from use with the latter's engine on the VX220. So if there was a way to monitoring the cycling / running of a regen cycle then he could produce something to monitor it.
catch
[quote name='Chutney' timestamp='1320446615' post='151348']
I think you missed the point I was making........but never mind it' not worth labouring at the "type face" to explain it....suffice to say I don't think anybody thought you were insinuating anything..... :rolleyes:
Yeah, I will probably see it on the UK's most reliable car report - damned devil car!!!
And yeah, I was guilty on buying the Focus too... thats why I spent a good few weeks researching my Cee'd before I went to look at one! its a philosophy of life I have learned the hard way...
james_60
Hi
Mods please can we construct a stickie about this as iam sure new members and people with focus's that have dpf's will all be asking the same two questions
Does my car have a DPF
Iam worried that it will be broken what shall i do
Jamie
Full Colour Version: Regen Problums
