Wickwick10_1
October 27, 2011, 3:52 pm
Tried to change bulbs in my wing mirror on new 2011 Focus but can't get the cover off !!!! Manuals no use either ......??
cuke
October 28, 2011, 4:23 am
Hi, when I removed my wing mirror on my mondeo, same as, I had to carefully use a small screwdiver, however you have to be very gentle not to damage the cover and its fixing lugs, I seem to remember squeezing the cover as well. You know when replacing the puddle lamp bulbs you don't remove the covers don't you.It is in the manual.
Chris
Wickwick10_1
October 28, 2011, 4:28 am
[quote name='cuke' timestamp='1319793782' post='150280']
Chris
It's the puddle lamp bulbs I want to change - so I don't need to remove the cover for these ? Manual is crap - just says remove carefully ??
tomo2001
October 28, 2011, 5:12 am
[quote name='Wickwick10_1' timestamp='1319794113' post='150283']
It's in the manual page 65/66 they're called 'Approach Lamps' - you have to remove the mirror glass first. Seems pretty straight forward ? Good luck !!
cuke
October 28, 2011, 5:32 am
Hi, paul is quite correct, this procedure is slightly different from that on the Mondeo...
Chris
Nigel S
October 28, 2011, 7:08 am
Do you mean the indicator bulbs?
If so, my Haynes manual recommends that you remove the mirror glass first so you can get easy access to the clips holding the back on.
Sounds like a case of it being much easier if you do something else first. Trying to work around will only cause extra work and probable broken parts (or temper).
cuke
October 28, 2011, 7:43 am
Hi, if you read his posts chris has already said it is the approach(puddle) lamps...
Chris
Wickwick10_1
October 28, 2011, 12:30 pm
[quote name='Nigel S' timestamp='1319803708' post='150305']
Temper yes !!! Lol Goid call to remove mirror for indicator too - thanks.
tomo2001
November 14, 2011, 12:27 pm
Hi Chris
Did you ever manage to change the bulbs ??
Wickwick10_1
November 15, 2011, 2:57 pm
Changed both my indicator bulb and puddle bulb by tilting the mirror as far in as possible and put fingers behind glass and pop mirror out - this was so easy mate and all done in 5 mins.
tomo2001
November 15, 2011, 3:11 pm
[quote name='Wickwick10_1' timestamp='1321390670' post='152746']
Was it worth the effort ? Are the puddle lights now bright white like the number plates ?
Wickwick10_1
November 15, 2011, 4:27 pm
No effort mate easy and bright white - may go blue tho ??
Tanda
October 14, 2012, 8:21 am
I'm having the same trouble, trying to change the indicator bulb. How does the mirror glass,"Pop" off, don't want to break anything, especially if you start leavering the mirror glass off, won't it break? and where and how do you get the clip off for the cover? Thanks for any help.
