Full Version: Guide To Fitting Door Handle Smd Led's Mk2.5
Ford Owners Club - Ford Forums > Ford Models > Ford Focus Club > Ford Focus Guides
Pages: 1, 2
Preee
This is a guide on fitting SMD Leds into the door handle Mk2.5 Focus.
Tools Needed.:
Large flat head screwdriver
8mm socket and driver
Multimeter
4 x Scotch locks
Insulation tape
4mm drill bit and drill
Marker pen
What i'm fitting is a 3 light SMD , they come in longer strips and can be cut down , These depending how you wire them can glow RED/BLUE or GREEN.
[url="http://www.ebay.co.uk/itm/120601332027?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649"]http://www.ebay.co.u...984.m1439.l2649[/url]
[img]http://img52.imageshack.us/img52/6894/20111029131106.jpg[/img]
By [url="http://profile.imageshack.us/user/preeee"]preeee[/url] at 2011-10-29
Picture Heavy
STEP 1
Removing the door panel , First start by squeezing the top and bottom of the plastic door trim by the handle and then prize from the window switch or alarm switch side.
Pulling gently until it unclips , use a flat screwdriver if you can not get your finger nails behind.Once released unclip the wiring.
[img]http://img713.imageshack.us/img713/5295/20111029112035.jpg[/img]
[img]http://img202.imageshack.us/img202/8585/20111029112117.jpg[/img]
STEP 2
With a flat screw drive move to the bottom half of the handle cover , insert the screwdriver and push down and work your way across until lower handle comes down and remove.
Undo the 2 x 8mm bolts underneath the door handle and remove. If working on the drivers door unplug the window and mirror wires.
[img]http://img515.imageshack.us/img515/6725/20111029112234.jpg[/img]
[img]http://img706.imageshack.us/img706/8103/20111029124500.jpg[/img]
STEP 3
Inner door card is held by 7 clips , easy way i found to remove was start at lower edge getting my fingers behind and using a large flat screwdriver rest it next to the clip and twist
to unclip, cover the screwdriver with a rag first.Then work your way along the bottom and side's then the top leaving the one by the mirror until last as there is a small section behind the mirror trim.
[img]http://img69.imageshack.us/img69/3812/20111029163818.jpg[/img]
STEP 4
Checking which wires so out with the multimeter, wiring is different.Passenger side the switch is the power window, drivers side is the alarm sensor turn off switch.
Passenger side wires to wire too are Green/Black + and Black/White -
Drivers door wires to wire too are Yello + and Black/White -.
[img]http://img338.imageshack.us/img338/6434/20111029130833.jpg[/img]
[img]http://img268.imageshack.us/img268/1102/20111029130851.jpg[/img]
Continued in next post
Preee
STEP 5
Mark door handle trim with placement of LEDS as shown and drill 3 x 4mm holes.Make sure you are drilling the top of the trim and not the bottom.
Try LEDS against the holes and use Wide 1 inch insulation tape to secure LEDS to the trim.
[IMG]http://img534.imageshack.us/img534/5369/20111029131705.jpg[/IMG]
By [URL=http://profile.imageshack.us/user/preeee]preeee[/URL] at 2011-10-29
[IMG]http://img401.imageshack.us/img401/2600/20111029131851.jpg[/IMG]
[IMG]http://img291.imageshack.us/img291/1558/20111029132447.jpg[/IMG]
STEP 6
Scotch lock + LED wire to Green/Black and - LED to Black/White .Switch on ignition to test.
[IMG]http://img192.imageshack.us/img192/1497/20111029132647.jpg[/IMG]
[IMG]http://img97.imageshack.us/img97/2935/20111029134120.jpg[/IMG]
STEP 7
Slide door handle trim through door hand gap in door card and position clips over the clip holes starting with the top corner by the mirror.
Push against door card in the corner and then align the top and again pushing door card until clip clicks into place , carry on arround until doorcard is back in place.
Replace the 2 x 8mm handle securing nuts and lower door handle trim.
Pull handle forward and slide handle trim behind the handle , reconnect the wiring plug , and clip back into place.Passenger side is complete. :).
[IMG]http://img515.imageshack.us/img515/428/20111029134222.jpg[/IMG]
Drivers side continued in next post.
Preee
STEP 8
Drivers side follow previous steps apart from the wiring.
The wiring in the Drivers switch is different as its not the electric window switch , it is the alarm sensor off switch.
Wire + LED to Yellow and wire - LED to Black/White.
[img]http://img510.imageshack.us/img510/6430/20111029145336.jpg[/img]
[img]http://img27.imageshack.us/img27/2193/20111029151239.jpg[/img]
[img]http://img830.imageshack.us/img830/2929/20111029152026.jpg[/img]
What i will say is. The passenger and rear Passenger doors all work differently to the drivers door.All the passenger doors light up when opening the door or switching on curtesy lights.
This stays on for 3 seconds , when ignition is turned on it lights up full time , when ignition is turned off it stays illuminated for 3 seconds and then goes off after you leave the car.
The drivers door however only come's on when ignition is on and goes off when you turn ignition off.
Oviously they are not on the same circuit , but i have tested all other wiring there and the same circuit is not in the drivers door.You could however trace a wire from the rear O/S door to the
drivers door if you wanted them to all act the same. But i'm happy with it as it is for now.
just got to order 2 more SMD leds for the rear doors now.
[img]http://img705.imageshack.us/img705/869/20111029191800.jpg[/img]
Thankyou for looking at my Guide.
Paul.
Quality Guide mate,
and the red led's in the door handles look great, very nicely done with the led fitted inside the panel and the holes allowing the beam through. B)
Preee
Cheers Lenny , just ordered another 2 Leds so i can do the rear doors.:rolleyes:
As soon as the long strips turn up i'll do the Cup Holder Guide
PaulB1803
Cheers Pree, thats agreat little mod, and a brilliant guide. Going to order some of those myself i think. How long did they take to arrive from that seller? May as well order 2 sets, and do both front and back at the same time. :)
HeadShoT2009
Looks great, if only there was someone who had done something like this with a Mk1.
Preee
[quote name='PaulB1803' timestamp='1320007988' post='150628']
They took 8 days to arrive , i ordered 2 more for the rear doors on Sunday so hopefully i will be fitting the rear doors as soon as they arrive.
Preee
[quote name='HeadShoT2009' timestamp='1320008445' post='150630']
I would imagine as long as you have power in the doors then it would be easy to do the same , if you have power windows which light up the switch then they would light up with the lights on. All you would need is a multimeter to check the wiring and if no poewer to the door then trace a wire through from the curtesy lights.
PaulB1803
Sorry for the stupid question, but what exactly do i need to connect the wires together? Any chance of a link? :)
Preee
[quote name='PaulB1803' timestamp='1320079719' post='150706']
Scotchlocks , you can get them from Ebay or Halfords they allow you to join into a wire with out cutting into it.
[url="http://www.ebay.co.uk/itm/10x-Blue-Splice-ScotchLok-Scotch-Lock-Snap-Lok-/160514640242?pt=UK_In_Car_Technology&hash=item255f6b0972"]http://www.ebay.co.uk/itm/10x-Blue-Splice-ScotchLok-Scotch-Lock-Snap-Lok-/160514640242?pt=UK_In_Car_Technology&hash=item255f6b0972[/url]
PaulB1803
Thanks Preee. :)
Preee
:D Not a problem let me know how you get on fitting the LEDS
Preee
Second batch of LEDS arrived Friday so while i was doing my cup holder mod i fitted the
rear door Handle lights as well.
This is on Titanium Model so power window's all round and an easy place to wire from.So now all Four door handles glow :D
Difference to the rear windows are the wiring colours, from the electric window switch the wires are :
left to right ---
Yellow/white +
Black/Orange -
Blue/White + This is the feed i used which has 3 second delay , so lights stay on after ignition off
Black/Orange - This is the feed i used for negative return other Black/Orange does not give a negative circuit.
Every thing is virtually the same as starting post apart from the wire colours.
[IMG]http://img204.imageshack.us/img204/9199/20111105095851.jpg[/IMG]
By [URL=http://profile.imageshack.us/user/preeee]preeee[/URL] at 2011-11-05
[IMG]http://img690.imageshack.us/img690/4258/20111105100457.jpg[/IMG]
[IMG]http://img690.imageshack.us/img690/5586/20111105101419.jpg[/IMG]
[IMG]http://img257.imageshack.us/img257/2660/20111105103536.jpg[/IMG]
[IMG]http://img839.imageshack.us/img839/1531/20111105104256.jpg[/IMG]
PaulB1803
Got mine fitted yesterday morning. Encountered a few problems along the way though.
Broke a clip on the rear driver side door card putting it back on :( decided to fit the rest without removing the door cards. It was a bit more fiddly but I managed ok. Scotchlock connectors refused to make a proper connection so I ended up stripping a small part of the cable and then using the scotchlock. Even though mine is also a titanium, the wires were different colours to preees. Not having a multimeter I judt poked the led cables in the ends of the comnector to see which worked.
All in all, I'm really happy with the result, and even the missus said they looked better than she expected!
Thanks again preee. :)
Preee
Hi Paul
I agree they look really good and i'm happy with mine , my wife never noticed haha , the only thing she likes about my car is the heated seat's lol
Wires are a littel thin and i had to strip them back then double them over when i did the rear doors , but on them the scotchlocks were from a different place so mayber a little wider
Preee
I think these are the clips to replace the broken one you have
[url="http://www.ebay.co.uk/itm/10x-Ford-Interior-Door-Card-Panel-Retainer-Trim-Clips-/270818179000?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3f0e0577b8"]http://www.ebay.co.uk/itm/10x-Ford-Interior-Door-Card-Panel-Retainer-Trim-Clips-/270818179000?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3f0e0577b8[/url]
[quote name='PaulB1803' timestamp='1321788563' post='153279']
Ive Just Found a perfect Match for the Door Handle SMD's Mate
Red led Air Vents for the Mk2 and Mk2.5 on ebay [url="http://www.ebay.co.uk/itm/170734073933?ru=http%3A%2F%2Fwww.ebay.co.uk%3A80%2Fsch%2Fi.html%3F_from%3DR40%26_trksid%3Dp4712.m570.l1313%26_nkw%3D170734073933%26_sacat%3DSee-All-Categories%26_fvi%3D1&_rdc=1"]Click Here [/url]
PaulB1803
hmmm, might be one step far those lol
[quote name='PaulB1803' timestamp='1321918009' post='153463']
:lol: i think they look good,
id actually buy them if i had the cash, they dont seem too bright or glaring in the second picture of the night shot,just a soft glow B)
Preee
[quote name='Lenny' timestamp='1321916160' post='153454']
They look cool Lenny , they look like they would just add a small glow to the Vents , problem with my Ebay is i use the UK site and it does not pull Ireland Ebay items up maybe i should use Ebay.com instead i'm missing all the good stuff lol
i have seen on youtube similar stuff like this
[url="http://www.youtube.com/watch?v=eZUZLJu8qe4&feature=related"]http://www.youtube.com/watch?v=eZUZLJu8qe4&feature=related[/url]
PaulB1803
Don't get me wrong, they do look good. The way things are going we will all be driving focis with huge red glows around them from all the LEDs we keep fitting. :lol:
Preee
[quote name='PaulB1803' timestamp='1321986096' post='153523']
:lol: haha very true.
I don't have anything left to fit now , i'm just waiting for my DRL's then i'm set for the winter
Paul did you manage to take any pics of your Door lights?
PaulB1803
Not yet. May nip out in a min and take some though.
One thing i have noticed is that if passengers use their buttons to open/close the windows, the LEDs go off, but the button light doesn't :unsure: they come back on when the button is released though. Do yours do this? Also, my drivers door one behaves slightly differently to how you described yours too. It stays on after the others have gone off when leaving the car. I think it stays on as long as the dash display.
Can't wait for the guide on those DRLs mate. I'll have to wait until after christmas for some though. :(
Preee
yes if the window switch is pressed the lights go off until the button is released . Must be some thing todo with the way they are wired .To be honest i have never watched the drivers door light go out when leaving the car, i will have to let you know on that one, i was meaning to route a wire fromt he rear o/s door so they are all wired in the same circuit as my drivers door switch appears lighter as well , or maybe thats me being sat by it , not sure
jane_b
hey i found something intersting on some russian forum i hope someone can translate and make a how to
http://ffclub.ru/topic/74863/#entry2604337
just a good idea :D:D:D
[b][u]Be warned - it's a load of gobbledegook.[/u][/b]
[b][u]Good luck.[/u][/b]
Top of Form
I plan to put on each door, two flashlight:
A. Red - to the ends of the casings of doors to other drivers in the dark could see the position of the open door.
Two. White - the bottom of the skins to see in the dark to attack, getting out of the car.
To do this, bought four VAGovskih red lantern (mounted on the ends of Audi's door skins), and four white torch light luggage Focus hatchback.
I want to make the inclusion of each door separately, ie, what door you open, on the lanterns and lights, while the remaining zakrtyh do not burn. For this connection to find 12V analog signal from each door separately.
As I understand it, the signal to open the doors give the castle, and a complete set of doors Ghia, this signal is on tsiforovoy bus.
Thought for connecting lanterns to put CAN-module, but the instructions written that CANy give a separate signal only the driver's door and other doors all together. There is the idea to put limit switches in the front door, but something did not really want to drill and kalhozit Fedka.
Can be those who have ideas on how to be plugging in the Ghia lanterns each door separately?
# Edited: Pyzhik, February 25, 2010 - 21:32
FF2 door. door lights, lanterns, lights in the cabin
Posts: 422 | Views: 72,036 | Link
Pages: 123 ... 11>
Mamok November 14, 2007 - 22:46 #
A
It is unclear why this is the standard does not shoved into Givi.
Deon November 14, 2007 - 22:50 #
A
I also do not understand! The car did a decent, and the details of kopeeshnoy saved!
.. :: STudent :: .. November 14, 2007 - 22:55 #
0
I have a trend with 4 lifts EFTA lights okolodvernogo space mirrors ............. one of the described functions they serve you in the pool does not occur
Mamok November 14, 2007 - 22:56 #
0
Hmmm. And what a Givi tada it not? UO can be good for?
.. :: STudent :: .. November 14, 2007 - 23:10 #
-1
Mamok
trend of taxis in Gia for her extra charge 290 ye
sanekk November 15, 2007 - 9:42 #
0
I know how! I've thought about it. These lamps must be connected to the door module to the terminal, which activates the backlight okolodvernogo space (number of contacts are looking for in the subject set in the mirror turn signals). But the question is, when you open the left door, mirror on the right torch is lit, too? Will there be some sort of reaction to the back door of the door module (or only function is implemented in the front)? All should try to ...
kamena November 15, 2007 - 10:08 #
0
QUOTE (Deon @ Nov 14 2007, 23:42)
And why so basically, let burn all need not rack your head, connect the lights on the legs and everything!
I'm so energized with light rapids and I was not how much breaks off the fact that others also lit at the opening of a door, you still can not see them!
Also wanted to highlight in the door, but forgot to buy a ceiling lamps, before sizing machine, then again, did not want to disassemble the casing.
sanekk November 15, 2007 - 12:24 #
0
Deon
And how much money is worth flashlights? And I did everything I wanted with the car, and now boring, itching, I want to take up the lanterns.
skipiribiba November 15, 2007 - 12:27 #
0
Does anyone know: a default in the solid trend is wiring for the lights okolodvernogo space?
sanekk November 15, 2007 - 12:54 #
0
skipiribiba
No. Moreover, there is even a module to control it (unless you have all 4 power windows).
Alexx72 November 15, 2007 - 13:53 #
0
Mamok
I ordered lights in the mirrors of the option-manager warned that this option may be incompatible with the "Gia" in principle
The car came without this option. . (The rest of the bunch was present)
The search led to the fact that of.diler said, installing lighting, it is necessary to start a door CAN-bus, ie This section of the wiring is different in "Gia" and "trend".
In general, the dealer does not come from behind ...
I agree that could be in "Gia" this option and leave the business-that-
Gidropon November 15, 2007 - 14:20 #
0
Good people! Tell me, where you can set the backlight okolodvernogo space?
-Volk-November 17, 2007 - 23:18 #
0
QUOTE (Gidropon @ Nov 15 2007, 13:20)
Ask, and you agree to establish a service neofitsalov.
Jennik1 November 17, 2007 - 23:41 #
0
As for where to install - I do not know
How to install but the answer - as a Scorpio Ghia - just perfect the mechanism of
think fit and, most importantly it = specials. thought h lights .... and fixtures
sanekk November 18, 2007 - 12:17 #
0
Alexx72
Just the same, if you Gia, the installation of lighting and perhaps only here. Only ubb have door modules, which connects lights. Look for additional equipment to the topic how to do it, there's not much to read.
No Fear November 18, 2007 - 12:58 #
0
Deon
Look here
http://foto.mail.ru/mail/muzzy2001
I am currently doing on the 3-door hatch. Put lampshades on VW TOUAREG white and red.
Powered by a light foot and pulled the wires in the door. Goes along with regular backlight shades gradually.
Deon November 18, 2007 - 15:44 #
0
No Fear
For your reference message: "Unfortunately, the pictures you requested is not available"
Jennik1
Can be a little more out there that a different mechanism for such a Scorpio Ghia?
Deon November 18, 2007 - 15:59 #0
QUOTE (sanekk @ Nov 15 2007, 11:24)
Deon
Red 322 rubles per Thing. They are built with patronchikami and lights. Not very cheap, but nothing suitable in quality and an external view of the domestic avtofonarproma I neshel. We establish these lanterns on VW and Audi. They come in red and white. With the help of whites can podvsetit space under doors.
But in the bottom of the door I bought a Ford, they are unloaded, the price of 133 rubles. a little thing. Patronchiki them bought Yuzhke to 15 rubles.
malenkiy November 19, 2007 - 23:42 #0
Deon
zapytyvaete both ceiling on the relay if ka UTB lights lkolodvernogo space and sewed it ...
Jennik1 November 20, 2007 - 0:08 #0
Deon
The mechanism is such that - 5V lamp is inserted into the base and twisted on the floor turn into a flashlight
everything is very tightly (I even tried the water again), and reliable. There can be no closure, there can not get damp and dust, ...
I'm on Skorpen stand - in the evening really helps * a * = a spotlight people think that Lincoln podehat)))
The most important thing - they were made for this plant!
And the price of = - for any disassembly. (They are like new)
A Focus on doors thicker than the scorpion like - so have to get up!
Deon January 30, 2008 - 23:43 #
2 I put lanterns in the door and connected, each door separately!
By highlighting a contact in the mirror okolodvernogo space, as some have suggested formuchane in this thread, I originally did not want to connect. Do not want to be when you open one door included six torches to the other closed! So I began searching for possible inclusion lanterns each door separately.
How did you manage to find an experimental way with the almost complete dismantling of one door, a signal for opening the doors to the assembly of the door Ghia is not for no CAN-bus, as in the usual form of analog, 12-volt "minus." But only this "minus" a little bit tricky. He appears on the wire when the door is closed and when opening is disabled. That is, all the way around, the door is closed - "minus" is, is open - "minus" no.
Therefore, the need for connecting lanterns to solve the problem, how to activate lights when power is off.
The first thing that comes to mind is to put pyatikontaktnoe relay. But this idea is not very suitable, since the closed-door four-winding (each door), the relay will consume current, and discharge the battery.
The second connection option - setting the buttons in the front-door switch, but this idea is also not the best. Drilling Fedya, somehow it did not want, and dragging wires from limit switches on the doors is not very pleasant procedure, with a corresponding removal of the front doors.
So I decided to try to implement the third option to connect using an existing signal at the door, but without the use of motor pyatikontaktnogo relay. At the forum I was advised to connect radioelektronschikov bulb with a simple shemki built on field-effect transistor. So I did. To connect to the three took podklyuchtitsya provdam at the door (the door opening signal, the "plus" and "minus"). All these wires are already there in the doorway and additional stretch is needed.
Colors of the wires in the door, which is a signal of opening:
Front left - yellow-black
Front right - blue-black
The rear and left and right - orange and black
Friends, I hope you understand that the above principle of operation signals the opening of doors and colors of the wires - this is not an instruction how to connect the lamps in the door any TRICKS complete Ghia, but the story of how I attached them to his car (07.2007, the a.). On other machines complete Ghia colors of the wires and the principle of the door opening signal, most likely the same, but there may be others! All must be checked!
Torches punched in the shell doors. But not just by setting them outside and drowned inside the casing (spied on a neighbor, as these lamps are in the Audi from the factory). To do this, do the holes in the casing to form the outer part of the flashlight, and the inside of the glued area, cut from plastic casing in the form of a flashlight. And it happened that the body of the flashlight is inserted in the casing is not, and in the playground, pasted under it, and the outer part is flush with the surface of the shell, without speaking of it.
Foty below:
Deon January 30, 2008 - 23:56 #0
Here foty site on which the lantern:
sanekk January 30, 2008 - 23:58 #0
Deon
Cleve, I already thought of this year, the head is worn on this setup ... More information can be on the connectors, of which he took the signals? Of the connectors on the modules? Or on the locks? And shemku describe in more detail it would not hurt ...
Deon January 30, 2008 - 23:58 #0
Ischo
Deon January 30, 2008 - 23:59 #0
and ischo
Deon January 31, 2008 - 0:06 #A
To the light from the light bulbs did not shine from all the cracks of doors skins, each with a flashlight inside the casings casing made from a plastic beaker for pens. The inside of the hulls painted stationery fonarkov stroke. White hull has significantly increased the brightness of torches, especially whites.
Deon January 31, 2008 - 0:08 #8
Of course a lot of fuss, but the result is worth it. Even turned off, lanterns look in his place, in the factory. Well, look at all included awesome! When you open the door in the dark, fine white lanterns illuminate the road surface near the car and see where to attack, getting out of the car, and the red bright lights are clearly visible from far away to other drivers!
Deon January 31, 2008 - 0:08 #7
Ischo phot
Deon January 31, 2008 - 0:23 #0
sanekk
The wire to the signal comes from opening the doors of the castle and goes out the door to the salon directly, bypassing the door module. Since the lock up is not very easy to reach - it is necessary to remove the panel from the window, I simply connected to the wire in the most convenient location.
sanekk January 31, 2008 - 0:25 #
Deon
With your permission, let me finish the wires, which is a signal the opening of the door, and just to correct you.
Front left - four contacts on the connector lock a black and yellow
Front right - 4 contacts on the connector lock a black and blue
Rear doors - 4 contacts on the connector lock a black and orange
All these wires go to the GEM module out the door without hitting the door modules in the analog signal. Even on the bus CAN GEM includes posvetku and sends a signal to open the door.
What is the connection - see image
A bit ahead of me ...And yet, pliz write, with pictures, that the scheme did you use? Where they took the other two signals? I can not understand the schemes more ...
# Last updated: January 31, 2008 - 0:30
Manu January 31, 2008 - 0:28 #0
Deon
class! 5 +!
Deon January 31, 2008 - 0:34 #0
sanekk
That's right!
But I take the signals from the wires before they reach the GEM module, since connected directly to the door. So, what's next with these Segal makes GEM module to work my light has no effect.
Shemku lay sha!
sanekk January 31, 2008 - 0:36 #A
Deon
I understand perfectly, this was a retreat as it were, to say this, that the wires do not go to the modules ...
All the same, which powered the rest? Where from? The land is clear, with 18 contacts on the module door, the black wire. By the way, with 16 contacts the door module signal goes to the castle, and then out of it is spent on GEM, there is an idea to cling to the module, it's easier, and at break of the chain in the lock, the signal is lost as a wire to the castle, and on the wire after (to which the neck connected).
The main thing is not to be confused black-and-yellow and yellow-black. Value of a different color. The first - black with a yellow stripe and the other yellow with black stripe. On the other - by analogy.
Deon January 31, 2008 - 0:54 #2
Here shemki lights turn off when the door of "minus" to lock the door.
Used to restrict a field effect transistor and the constant resistance IRFZ44N 10k power 0.25W
The signal from the lock at the "gate" taranzistora, and the "plus" and "minus" is in each door. Orange with white stripe - a "plus", and black, respectively, the "minus". They both fit in the slots of door modules (number pad, unfortunately I do not remember, but I have no scheme). But they are easy to find the color and they are two very thick.
Deon January 31, 2008 - 1:53 #9
The boards did not do any. Circuits soldered together and priapayal wires to them. Got this thing. Then he shoved all-in shrink.
If a man have any questions, you are welcome!
-Forester-January 31, 2008 - 2:24 #0
Deon
MegaZachOt!
new theme for those who have "itching"
Posted at 02:28 **
PS while the red lanterns there are some code or reference, well, or as a short seller to explain what I want?
Deon January 31, 2008 - 2:46 #2
Finis-codes:
Red lanterns VAGovskie: 8D0947411
There are more such VAGovskie, but white: 3B0947415B
I put white lights on the Ford hatchback trunk: 6136623
dimka1 January 31, 2008 - 9:18 #0
Deon
MegaZachOt! Boom to do.
The only downside, if the lamp blows, the transistor, the resistance - to replace the need to remove the door trim, is not good!
(Prompt: - and to set the ceiling outside the place enough - strike sharply on the thresholds would not be?)
sanekk January 31, 2008 - 9:36 #0
Deon
And which of the wires connecting light on the pictures, what is the earth, from what is 12B?
I look at my chart and I can not understand what the picture is that ... You can paint the flowers?
What color is the wire to the signal door? What kind of advantage? What with the land?
As far as I could figure out the scheme, and a picture, black - ground to the door.
Green - the signal from the lock.
Orange - 12 V through a resistance, there is a positive lead to the bulb.
White - the land, stretching from the transistor to the bulb.
Home forumaPoiskAvtomobili - Ford Focus ---- FF1 Extras. Equipment and Parts - Ford Focus 2 ---- FF2 Operation ---- FF2 Accessoires and Parts - Ford Focus 3 ---- Engine ---- Chassis ---- Brakes ---- Body and Salon ---- Electrical ---- Optics ---- Wheels ---- Audio, multimedia, navigation and safety systems ---- help ---- Protection Systems ---- Feedback - Ford Focus ST - Ford C-MAX - Ford S-MAX and Galaxy 2006 - Ford Mondeo - 4x4 ---- Ford Escape and Maverick ---- Ford Kuga - Ford Fiesta, Fusion - Commercial vehicles - Diesel engines - Dealers, Services, FMC - Parts and Services WE - Introductions - Around and Inside - Avtobesedka - Archangel Club ---- ---- Novgorod, Vladimir ---- ---- ---- Ekaterinburg Kazan, Ivanovo ---- ---- Kaluga - - Kirov Kostroma ---- ---- ---- Krasnodar Krasnoyarsk Kuzbass ---- ---- ---- Magnitogorsk Moscow Murmansk ---- ---- ---- Nizhny Novgorod Novosibirsk - --- Omsk - Archive ---- ---- Perm Pskov ---- Republic of Karelia, Komi Republic ---- ---- ---- Republic of Mordovia, Rostov-on-Don, Ryazan ---- - - Samara ---- St. Petersburg ---- ---- Saratov Sergiev Posad, Dimitrov ---- ---- Stavropol Tver Tomsk ---- ---- ---- Tula Tyumen - - Ufa ---- Chelyabinsk Cherepovets ---- ---- ---- Black Earth Ugra ---- Yaroslavl ---- Belarus ---- Ukraine ---- FF Racing Club - Archive - Sport - Travel - Hobbies - For Sale ---- Marketplace - For Sale ---- Wheels - Car Audio ---- For Sale - Car - For Sale ---- Sale - Wheels ---- For Sale - Car Audio ---- Sale - Cars Others Topics - News - ffclub.ru - Website
Up
Write:
Related Topics:
FF2 Accessoires and Parts - Replacement of rear lights in a wagon with restayla on doreystal and back,
FF2 Accessoires and Parts - Guide to Alternative optics
FF2 Accessoires and Parts - Rear Optic LED IN.PRO
FF2 Accessoires and Parts - Installation of rear diode lights on HB
FF2 Accessoires and parts - rear LED lights on the sedan
FF2 Accessoires and Parts - Lights handle PPC
FF2 Accessoires and Parts - Rear optics In.pro. - Turning blinking
FF2 Accessoires and parts - Tinted optics
FF2 Accessoires and parts - report on installing lights the door handles
FF2 Accessoires and Parts - The second reversing lights, better lighting sx
FF2 Accessoires and parts - lighting devices peresvetka
FF2 Accessoires and Parts - Alternative optics (v2.0)
Ford C-MAX - C-MAX 2: optics: rear lights
FF1 Extras.
Preee
It sounds as if they are putting White puddle lights on the bottom , red lights to the side of the door , so when the door is open in the dark it will show a red light so any one approaching fromthe rear will see the red light , you get these on alot of hight end cars
jane_b
yess preee it is like audi and bmw benz ... i just didnt know how they where instaling the lights i undestand everything exept the wirring part from which conection r they taking the power for every door seperatly.by the way i just like the look and is also safety when you open the door:D:D:D
Bigdaddycain
I found that russian translation quite an entertaining "little" read! Very amusing, though i'm not certain whether it's a good, or bad thing that i got the gist of most of it!
Great write up Pree! After reading up on all the LED "how to's" on here this evening, i've decided to take the plunge, and order all the bits & bobs to illuminate the: Front and rear door handles (blue),puddle light each door (white SMD strip), Maybe use a 3SMD strip on each door jamb as a door open warning light (red) And a couple on the leading edge of the tailgate (3 SMD strips) as a warning that the tailgate is open... I've noticed on some forum members interior images that there is a door below the heater controls covering up the cubby where the cig socket is, There's no "door" on mine, nor does there appear to be a method of attaching one... I was thinking of fitting an LED in there too, just to get the aperture glowing... If i did that little lot, then i'd HAVE to get my a**e in gear and sort out blue illumination for the complete dash and all the switches... Gawd knows how i'd get my Sony/ford double DIN head unit to light up blue though!
Preee
Bigdaddy.
JohnH has a great guide on how to change the LED's on the radio , his link is in his signature.
the red safety feature for the door open is a good idea i think , i have some spare low glow red Led strips i could use and may have a look at fitting them , only have 2 though. i like the idea of puddle lights but only if they were fitted to the mirror's , but fot me not using the remote key to open my car then i would be already stood in the puddle as i pulled the door handle so the puddle lights are not for me :)
PaulB1803
A couple of pics of mine that i did a while back.
[img]http://i37.photobucket.com/albums/e65/PaulB1803/20120219_153456.jpg[/img]
[img]http://i37.photobucket.com/albums/e65/PaulB1803/20120219_153442.jpg[/img]
Preee
Looks good Paul , did you do the rears as well?
Bigdaddycain
[quote name='Preee' timestamp='1329497692' post='167280']
Bigdaddy.
Cheers Paul ;)
Bigdaddycain
[quote name='PaulB1803' timestamp='1330207339' post='168835']
[/quote]Love it!
PaulB1803
[quote name='Preee' timestamp='1330293530' post='169055']
Yeah, but forgot to take some pics of them lol.
ijustwantafile
how come you have to take the door panel off? are you not just using the power that is already on the switches?
I might have a look into doing this at the weekend but don't have a drill with me so was thinking is there room to have a light come through on the gap around the plastic cover where the handle goes through...
Preee
[quote name='ijustwantafile' timestamp='1332851393' post='174617']
it's possible i guess but how would you secure the LED , and you would not want the door handle rubbbing against the wires or LED
ijustwantafile
[quote name='Preee' timestamp='1332876471' post='174688']
I fitted it earlier, this is what I manged to come up with:
[img]http://localhostr.com/file/s7tB9mq/image1.jpg[/img]
I'm waiting for it to go dark and I'll see how much light it show around the handle.
Also I'm still not sure why you have put in the guide to take off the door panel. I just popped the cover off and wired it up and put it back in.
I also noticed the light stays on for around 5sec then shuts off, at first I thought it wasn't going to turn off and I had wired it up wrong.
Preee
[quote name='ijustwantafile' timestamp='1333206197' post='175336']
Quite simply , my N/S wires were short so i took the panel off and it also serve's for if someone wants to take a panel off.
As it states ,it's a Guide people can choose the way they want to do it.
clubber
Ordered my LED's last night. Will be fitting these when I receive them. Another top guide Preee
clubber
LED's arrived today, fitted them to all 4 doors. Didn't bother taking door cards off. Just stick the wires into the existing plug and taped it up. Looks good and a worthwhile and easy mod. Can't wait for it to get dark!
Preee
[quote name='clubber' timestamp='1348332146' post='207767']
You will love the effect Clubber , i fitted some to my Nephews ST (facelift) the other weekend and the wiring was totally different , but got it working so it comes on with Ignition. looks great though he choose green Led's also did his cupholders so a nice tint of green inside the ST.
clubber
[quote name='Preee' timestamp='1348336472' post='207776']
The wiring in my ST facelift was exactly the same as yours apart from the back that were a slightly different colour combination.
Preee
Nephews is a two door , all all the wiring for the passenger door were, the electric window one shot up/down without ignition there was no power there at all even with the lights on.Thats why his only come on with ignition , seems wiring is different on a few Focus's
SkinnyB
Got mine in the post today :) very excited bout this little mod. I'm doing all my interior red (well red lights/led) so this will be a nice little touch. One question I have though I have a set of logo lights/ puddle lights, I'm not very good with a multimeter but I tried to find wires to connect them to so that they turn on when I open the door but there doesn't seem to be any wiring for this in my door. Anyone know how I can connect these little buggers? Looking to do a guide on it if I can find out how or where to connect the wires.
Preee
Where do you plan on fitting the Logo lights in the mirror's or bottom of the door?
You could run a wire from the interior light through the door rubber grommet , so they will come on when you open the door. If your fitting in the mirror then maybe you could get the power from the door lock , but not sure on that.
SkinnyB
[quote name='Preee' timestamp='1351363329' post='213969']
SkinnyB
I've already fitted them to the bottom of the door panel. As for running the wire from the interior light that's just a no go as I can't even get the metal panel off (which I believe is attached to the window or the window mechanism) behind the door card. There are 5 black wires running to the door lock I believe, I might just try that tommorow, looks like its back out with the multimeter for me. Will update tomorrow. Cheers Preee!
SkinnyB
Just a quick update, managed to connect the logo lights to the door lock, there is 5 black wires running to the door lock. 3 thick ones and 2 thin ones, connected ground to one of the thick ones and positive to one of the thin ones (having the multimeter at hand did help). Only thing in not that happy about is the logo lights themself
