Full Version: Water Has Leaked Into The Boot Plz Help
james_60
Hi
Just been checking car over as going to north wales relative visiting.
Noticed that the car must be leaking water.
The rear parcel shelf support on the passenger side in the boot has two access holes and inside there is a layer of foam.
The said foam is saturated with what appears to be water.
On removal of the rear tail light on the passenger side there appears to be two bungs.
One for the wiring and one for erm nothing it appears.
They both appear to be intact and secure.
My reason for this post is :
Where else could the water leak from.
Have had the car less than a month and it is a ford direct vehicle.
Will water leaks be covered.
Jamie :-)
Wickwick10_1
[quote name='james_60' timestamp='1319991418' post='150595']
Hi
Jamie :-)
Take it back to them let them find the leak.
H3lly
On the mk1 the rear window washer tubing comes loose and leaks into the boot. I would check this first.
Hi
Jamie :-)
Im 90% sure its the sealent fro the top of the rear window mate,
water runs under the rear spoiler and eventualy overtime the seal at the top of the rear window seperates and allows the water to leak in to the boot,
as a temperary measure you could rub vaseline along the flap of the rear spoiler where it jouns the roof,
this will help prevent water getting in until they fix it for you mate,
they will remove the rear window and reseal no worrys B)
[quote name='Lenny' timestamp='1319992129' post='150600']
a few possibilities the rear seal as stated also the spoiler if fitted needs to be removed then a decent sealant used on all the bolt holesthe foam stuff ford put on is useless water gets into these holes drips into the plastic trim and out onto the parcel shelf open the boot theres a plastic cover at the top of the window it just pulls off youll see water marks inside.
also the 3rd light foam seal goes youll know as it will be soaked i dried it out and then using clear sealant on both sides reattatched it and a dob of sealant inside the screw holes before reattatching no more leaks ford refitted the spoiler with new seals and it didnt work does now though
james_60
Hi
Rang ford today.
Car has been booked in for a full water leak inspection
Iam also getting that keyless door sensor replaced hopefully as sometimes when i get out and try to lock the door with the button it does nothing.
Jamie
james_60
Hiya
Took the car to Cutts Of Campden today for them to fix me leak
And fix the button on my handle
Jamie :-)
james_60
Hi Dudes
Collected car from cutts today.
Water was leaking from the left hand boot hinge They have said that they have sealed it up and then did a pressure test (Jet Wash Lance)
Will have to see if it has stopped leaking.
Door handle on drivers door is faulty that is apparently why the lock button on the handle is not working properly and they have ordered a replacement handle
All this work is under warranty so if anyone else has the above faults raise it with your Service Dept.
Jamie :-)
james_60
Dudes and Dudettes
Anyone home
lol
Jamie
Druberry
[quote name='james_60' timestamp='1321093050' post='152301']
Hi Dudes
Jamie :-)
Druberry
Hi Jamie
I hope this is the end of your problems but my focus is a 60 plate as welland reading about leaks ford are just not getting their act together, its an old model now so you expect these problems sorted. As you can see from my post, we should not be having these issues.At least you never had to pay for it. All the best Andy.
james_60
Hi Druberry
Problem has returned and the foam in the parcel shelf supports (ledges inside boot where parcel shelf sits)
Inside those shelves have foam inside and this is soaking on the passenger side.
Jamie
I was waiting to hear that if it was the hingerg then the headlining would be wet id remove the rear lights and check to see if they are filled with crud down the drain gulley clean it up then use clear silicon on all the holes including the screw holes then remove the rear spoiler and do the same remove third brake lite check if its wet make sure washer hose is attatchd and use silicon to seal that if theres still a leak then the rear side quarter window is leaking
