martyntp
November 3, 2011, 7:20 am
HI
New to this and need some help/advice.
2006 Smax 2.0tdci titanium. Absolutely love it but recently had problems with starting the car. It turns over reluctantly and then eventually fires, will sometimes need to try twice before it does. Asked ford at last service, but they were not sure, said it could 1 of several things. Then this morning it would start at all. In the end wouldn't even turn over properly. Connected it up to jump start it and bingo eventually it fired. So I have replaced the battery and again wouldn't start, turned over a few times and then would even turn over at all. Jumped it again and it started. Took it for a run to give the battery some juice, got home left it for 15mins. Tried again and at first it would fire, tried again and it wouldn't even turn over, then tried again and eventually it started. Wife has taken it to work, but now just waiting for the call that says it wont start again. Any ideas anyone? Oh and to top it all off it keeps telling me that the ford keycode i have is incorrect on the stereo, wonderful!!!
137699
November 3, 2011, 7:27 am
As it's a diesel if could be related to the DMF (dual mass flywheel) on the clutch.
I take it your dealer has applied the software update to the GEM & BCM to resolve the low battery issue that affected the early models? (i.e. the display on the dash and radio shuts off as soon as you lock the car? If it stays on afterwards then you have a battery drain and this could cause issues next time you start the car?!)
JezzaA
November 13, 2011, 10:20 pm
Hey up all, have an 06' s-max 2.0 tdci titanium which me and my wife love (and the kids), just started to get a couple of probs starting to appear, first one is the brake bulbs, first the offside stopped working then the nearside gave up the ghost, have replaced both and the offside has blown again! annoying. Fixing planes for a living the bulbs weren't to much off a problem, you do need bendy hands.
Second prob is that the MPG has dropped down and i have noticed smoke on hard acceleration, im hopeing its the EGR valve requireing a clean but im not too sure! if any one has any ideas i would appreciate some advice.
Thanks Jezza
finalspin
December 22, 2011, 9:48 am
[quote name='martyntp' timestamp='1320322808' post='151122']
HI
hi mate, i had the exact same problem with our 56 plate smax on monday, draikned battery, hard to start, hooked up jump leads and it started, my mechanic was with ford for 28 years and knows his stuff, i was dreading it being the dmf but thankfully it wasnt, turned out to be the starter, the armature was completely burned out and new brushes required, he got it refurbed, all this and only £80 inc labour... car is perfect now!
GrahamC
February 9, 2012, 9:51 am
Wonder whether there is any known systematic issue with Bluetooth module?
After a year and a bit from new, I experienced electronic issues which gradually worsened. Initially, the Bluetooth connection to the phone (HTC Desire if that is of interest) would drop out, with increasing regularity until it didn't work at all. Then I noticed the cruise control dropping out and hanging such that it was neither on nor off. Finally I experienced a fully flat battery.
Ford dealer indicated that the fault was just the Bluetooth module, and replaced it, after which the car worked properly again.
Now, after another year and a bit, I am experiencing the Bluetooth phone connection dropping in and out a few times per hour on my daily commute ...
Obviously I am concerned that there may be a pattern here ...
137699
February 10, 2012, 2:43 am
[quote name='GrahamC' timestamp='1328802670' post='165689']
There is a new bluetooth software update available - maybe that will cure your issue? You can download & apply yourself from the smax owners club website (providing you have the USB port), or you can pay for Ford to do it.
Hi all
New here and after a bit of advice. Got a ford Smax tdci 2.0L auto on 08 plate and it has started jerking when stopped at lights or a roundabout, as if the clutch is slipping. Could this be the case or am I looking in the wrong area? Its done 78K miles but mostly motorway. Any help appreciated before I chance the local ford dealer!!
137699
May 9, 2012, 9:30 am
Can be a failing Dual Mass Flywheel issue.
Uplands5
May 16, 2012, 8:16 am
[color=#BCBCBC][color="#000000"]Hi All,
Over recent months I have used this forum for info regarding SMAX troubles as I have experienced the Alarm/wiper problem and Power Steering Issues. I have found peoples comments an interesting point of reference, so hopefully my experience should help others.
I have an 08 SMAX and have had the Alarm module and Power Steering pump replaced last year under warranty, but after a few months the power steering started to whine again on and off, various visits to the local ford dealer and they suspected the steering rack at £900-£1000 as I am out of warranty!
I was not convinced and lived with it for a few more months until I’d had enough of the noise and stiff steering, I then decided to take the car to a large south coast ford dealer, they took a look and advised that it could be the rack. After some investigation they asked if the Power Steering Reservoir had been changed, I advised as far as I was aware no it hadn't. They advised this was the first course of action and I decided to go for it, £250 including the investigation time.
I now have the car back and I don't want to tempt fate but fingers crossed the steering is fine, it’s like a new car, I've had it since it was 2 years old (I've owned it for 2 years now) and I don't think the steering has ever been so good!
I will keep you posted if the fault reoccurs or not.[/color][/color]
ging
June 8, 2012, 4:15 pm
hi as some of you know i have had a couple of problems with my turbo on the 2.5 st bus but that is the least of hger worries a mounth ago she spat off the aux drive belt with no worning while tiking over on my drive sounds like nothink till i got her down to work the belt went round the cam belt and knocked out the timming bent all the valve and made a big mess i found when i stripped her down completely recked the motor gutted
137699
June 10, 2012, 2:36 pm
There is/was someone selling a 2.5T engine on ebay.
thomas56
September 7, 2012, 9:41 am
[quote name='maxxedout' timestamp='1276268273' post='84900']
Hi, New to this too but very frustrated - My S-Max is a great car and the alarm fault as described above was fixed in warranty as were the parking sensors however 9 weeks out of warranty the ABS pump has gone - started up all by itself whilst parked up and locked outside the house and almost caught fire - husband managed to get the battery disconnected in time.
Ford say £800+ for a new pump and not getting much joy from them even though its only 2 months out of warranty.
I love the car but they seem to have the same recurring problems that Ford deny. Has anyone else had this problem just out of warranty and how did they get on with Ford?
Oh and did anyone elses almost catch fire?
Have just had my second abs pump/module fitted same as yourself pump running all the time even with keys out of car, first time was in warranty but has cost €1600 this time round. Funny dealership has never seen this fault before and I have had it twice. Car is 2007 with 66800km on the clock.
S-Max clutch woes
September 17, 2012, 8:07 am
Help! This is our 2nd S-Max. First one (2007) had the brake problems quoted above. Eventually repaired prior to general recall, and when we asked if it should be upgraded at recal we were told "No" even though it had been repaired with the original, presumably faulty part. Result: about 4 months later we suffered one of those 'extremes of temperature' that apparently caused the fault in the first place, and the brakes failed on one of the steepest hills in London, in the snow! That was 2008, and we traded it in for another make. 2011 comes along and we decide to give the S-Max another try. This one started with a clutch smell which we were told was 'normal'. A week later we had a breakdown caused by the computer. A month or so after that the boot started popping open of its own acord as we drove along. Last month the clutch wore out. 10 months old, 8000 miles on the clock. We have both been driving 20 years and neither of us has ever needed to replace a clutch, despite owning cars for up to 8 years and about 100K miles. Ford Warranty says it's all down to our poor driving and 'wear and tear'. Now in the 3rd week of the new school year and the car has been at the garage since the last week of the holidays. No courtesy car. Latest news is that Ford have run out of the necessary parts. And they still deny there's a problem. What can we do?
lfcascao
September 24, 2012, 8:47 am
[quote name='Pacific' timestamp='1263683621' post='60359']
New to this as well.
Haven't experienced this persistent whining but know it from accelerating at high speed (motorway) - it is quite loud. Always assumed it was the turbo.
The problems I have found are:
[list]
[*][color=#0000cd][u][b]Faulty indicator switch (leading to parking lights coming on of own accord when the engine is off - potential battery drainer[/b][/u][/color] - and motorway hazard as indicators again could come on of own accord - it is a known problem and got it replaced under warranty.
[*]Other issue is how farcically difficult it is to change rear break bulbs [img]http://www.fordownersclub.com/forums/public/style_emoticons/default/mad.gif[/img] -has any one succeeded?? Please let me know
[/list]
Hello,
since every problem I had (not so many or headhachefull ones) were asked before and solved before (thanks all for that) I could't find any solution to my recent problem, a Faulty indicator switch (leading to parking lights coming on of own accord when the engine is off).
Does anyone know how to solve it?
My S-Max is a 2008 2.0 tdci, so without warranty.
Thank you for your attention
jpunter22
November 30, 2012, 2:01 am
Hi everyone
I have got a 2007 2.0 tdci smax and i have a few problems which I'm trying to get to the bottom of.
1. There is a constant whinning/buzzing noise inside the car. I have been told by a garage that its the electric power steering motor/pump and this is normal on these, can anyone clarify that this is the case as I'm not sure this is true.
2. When i'm driving the car I get a lurching motion at low settled revs (doing 30mph in 4th gear, in second when you are turning into junctions). There is plenty of power there when i accelerate a bit but when I let it settle again it starts doing it again. I have been told by the same garage its because its a heavy car and that I just need to be in a lower gear, which does sort the problem but I have never had in all my years driving a car that you have needed to change into first gear to turn into junctions or not been able to be in 4th gear doing 30mph. I have heard stories about the dual mass flywheels being an issue on these and was woundering if anyone can help.
3. Last one now. When i put the car into reverse the parking distances system does a continuous beep for about 10 seconds then only seems to work sometimes or eraticly. I have noticed that the rear sensors have no longer got the black coating on them and that there is a some white powder on a couple. Could this be the cause of the problem as the front ones are fine and seem to work still.
I would really appriciate some help on these issues if anyone has experenced or had similar problems, and how they were solved or if they can be sloved. Many thanks for any help in advance.
Jamie
Evovrs
January 23, 2013, 10:24 am
HELP!!!
Im stuck,,,
I work on a 2006 smax 1,8 tdci,
The turbo was broken, I've changed it, started an everything was fine, after 5 min I revded it to maybe 2500, and it started to overrev, it went on for about 10 sec,,
Then it stalled , after this it won't start, take it back into shop and check the inter cooler, it was oil in it, drained it out and tried starting, but no luck, I checked the fuel lines and the diesel is not there,
Checked the engine oil, and it was about 1 cm over the max mark, and the oil smell like diesel,
I've heard on Volvo 1,6 a seal in the pump can give away and send diesel to the pan, but can't find anything on this with the 1,8 tdci,
Anyone experienced the same?
Ste70
June 10, 2013, 2:03 pm
New to this I have a 1.8 tdci and the engine malfution light comes on and I lose power and 1 help
skinnydipper
June 18, 2013, 11:38 am
Hi all,
like most people on this forum, I've just joined because i've got a problem, but dont worry, looks like a good site, think i'll be back to see if I can pimp my ride a bit once problems are sorted.
Anyhow we've got an 07 s-max 2.5t, with full sports pack. It's only got 30'000 miles on clock. It's a great looking family car, absolutely rubbish on mpg, and I mean terrible, but is fun to drive, we've obut now got a problem with the steering.
Story is the battery in key fob started to die, ended up replacing battery after having to open doors manually for a week, but think it was too late as when I replaced it didnt work. Then same day power steering packed up, I thought this may be something to do with alarm/immobiliser. Took down to local dealership today. They say there's swarf in power steering fluid, will have to change pump and steering rack at a cost of £1750.
Now 30,000 miles isnt a lot, and £1750 is a lot of money, is this a common problem,
