First check my guide for making the LED setup.
[url="http://www.fordownersclub.com/forums/topic/28083-guide-to-cutting-and-soldering-smd-led-strips/page__pid__151331#entry151331"]http://www.fordowner...331#entry151331[/url]
Basic setup up is Ford Focus with armrest , but with out armrest there would be little difference.
Parts
9 SMD LEDS
Fuse holder and 3 amp fuse
Scotchlocks
Tools
T25 and T20 Hex screwdriver bits
Pliers
Drill and 4mm Drill bit
10mm Socket and driver
Multimeter tester
Flat head screwdriver
One inch wide insulation tape
STEP 1)
Lift armrest lid and undo two T20 retaining screws.
Lift handbrake surround up and over the handbrake.
[img]http://img265.imageshack.us/img265/4774/20111105113324.jpg[/img]
By [url="http://profile.imageshack.us/user/preeee"]preeee[/url] at 2011-11-05
[img]http://img196.imageshack.us/img196/585/20111105114437.jpg[/img]
STEP 2)
Lift out bottom section of cupholder , use finger nail .Undo the T20 retaining screw and remove.
[img]http://img683.imageshack.us/img683/5909/20111105114516.jpg[/img]
Step 3)
Using your finger nails pull up the gear stick plastic/chrome surround lift out and then un-screw the
gear stick knog anti clockwise and remove.
[img]http://img27.imageshack.us/img27/8080/20111105114615.jpg[/img]
STEP 4)
Pop out Start button or 12v Aux and undo the wiring clip.
[img]http://img440.imageshack.us/img440/8402/20111105115143.jpg[/img]
STEP 5)
Using a flat head screwdriver , start from the bottom of the radio surround , insert screwdriver covered with
a cloth and using a twisting action work your way from the bottom / middle and upwards until radio surround is free.
[img]http://img266.imageshack.us/img266/4125/20111105115825.jpg[/img]
[img]http://img828.imageshack.us/img828/2724/20111105115917.jpg[/img]
STEP 6)
Using T25 HEX screwdriver undo the two retaining screws and remover , un-clip the set of buttons.
You can now see the wiring for the buttons , i found two live feeds when lights are turned on.Furthest right (on mine)is the
wires used for the ESP or Electric roof on CC models Orange/White = +. Left of that are the wires for the Rear Demister
wire is Orange/Black + both of these are live when side lights are turned on.
[img]http://img151.imageshack.us/img151/9287/20111105115946.jpg[/img]
[img]http://img38.imageshack.us/img38/6582/20111105120640.jpg[/img]
Continued in next post.
