bt_cav
November 7, 2011, 8:27 am
Hi All
Im Looking to change drums, shoes, fitting kit & bearings
I am not sure what the deal is with the ABS ring, Is it easy enough to swap over after the bearings are fitted?
Brian
04 focus
hatchback
bt_cav
November 7, 2011, 12:28 pm
I have ordered these, hope the quality will be as good as they say.
I have a fitting kit already
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=300457001135
bt_cav
November 11, 2011, 3:32 pm
Parts arrived quickly
Can anyone advise me what is the best way to remove the abs 'ring' from the old drums, without destroying them. Or Must I buy a new pair?
Brian
bt_cav
November 12, 2011, 3:54 pm
Anyone?
November 13, 2011, 3:16 am
[quote name='bt_cav' timestamp='1321134895' post='152381']
Anyone?
can you put a pic up of the inside of the new drums? im thinking the ring it just pushed on or maybe a shrink fit?
alz
November 13, 2011, 12:45 pm
Have a look at this link it should help. (it looks like they should be replaced) as you could damage them, taking it off
[url="http://www.fordpartsuk.com/shop/ford_focus_rear_abs_sensor__ring_2642.htm"]http://www.fordpartsuk.com/shop/ford_focus_rear_abs_sensor__ring_2642.htm[/url]
bt_cav
November 13, 2011, 2:37 pm
cheers guys
if I build up the rear brakes with out the ring the ABS light will come on, will it go out when I fit new rings later?
bt_cav
November 13, 2011, 6:23 pm
As requested
jay1981
November 14, 2011, 6:52 am
I would try to transfer the old ABS rings on to the new drums. You could try prying them off using a screwdriver, then use somthing like a block of wood to press the rings on to the new drum. You have nothing to lose by trying, and if the the ABS light goes out then thats sorted, if it doesn't then you will need new rings.
[quote]if I build up the rear brakes with out the ring the ABS light will come on, will it go out when I fit new rings later?[/quote]
If the ABS rings are missing the the ABS light will be on, and the light should go out when the rings are fitted.
bt_cav
November 14, 2011, 7:14 am
Nice one Jay, thats what I thought but need to know for sure
November 18, 2011, 4:19 pm
might be a little late, if its those type of abs rings they are easy to remove/refit. get a large pair of pump pliers and a rag, and just twist it until it comes off. dont use a screwdriver or any sort of lever as you will destroy it. i thought that type only applied to rear discs (obv not then)
bt_cav
November 18, 2011, 4:46 pm
[quote name='stef123' timestamp='1321654746' post='153142']
Hey Stef
Cheers for your advice, I fitted the new shoes with a new fitting kit, I have new drums but just put the old drums on for now, as they are not so bad, will swap the ABS rings over and fit to new drums when I have time.
How would you go about refitting the ABS rings? Gently tap them on all the way round at oppisit sides i.e. 12 oclock 6 o'clock 3 o'clock 9 o'clock...
November 19, 2011, 4:39 am
[quote name='bt_cav' timestamp='1321656363' post='153146']
Hey Stef
I used a bearing driver which is just a large round piece of metal but you could do it that way or even a piece of wood over it and tap it in the middle. just keep an eye on it to make sure it goes on square.
bt_cav
November 19, 2011, 1:39 pm
Nice one I'll go easy and let you know how it goes......fingers crossed
November 19, 2011, 2:37 pm
[quote name='bt_cav' timestamp='1321731589' post='153232']
before i got a bearing press i once had my local garage press a bearing for me, the guy told me that you cant remove the abs ring without destroying it - soon sorted that
admittedly i have no idea how this will be on a drum, not sure if you will be able to get in with the pump pliers properly?
you will need a large pair of pump pliers though, i used a 12 inch pair as the jaws open really wide.
bt_cav
November 19, 2011, 4:56 pm
[quote name='stef123' timestamp='1321735057' post='153246']
Yea mate it makes a lot of sense, Got a couple of pairs of these, grate for pushing back pistons in calipers and slackening off oil filters too
bt_cav
February 15, 2012, 10:00 am
1 drum and ABS ring changed, Like you said Stef, got the ring moving with a pair of pump pliers then gently prised it off with a big with flat screwdriver
Off to do the other side now
February 15, 2012, 11:59 am
[quote name='bt_cav' timestamp='1329321627' post='166820']
nice work mate
Abs Rings On Drums
