BIGGSY
November 12, 2011, 8:44 am
I have a 1.8 petrol ford focus on a 59 2010 plate. when i start the car up the rev's idle very low then picks up. When i get to the end of my street and dip the cluth the engine cuts out and i have to restart the car again. does anyone know why this is or any solutions
many thanks
Cbiggs
H3lly
November 12, 2011, 8:49 am
Could be IACV (idle air valve) related or maybe there is a vaccum leak from the PCV (positive crank shaft tubing / valve). Are there any warning lights?
BIGGSY
November 12, 2011, 8:53 am
no warning lights, and it only does it one then when i leave over night to go cold it does it again?
Biggsy
james_60
November 12, 2011, 10:19 am
Hi Biggsy
Check the Battery Voltage at rest and when running.
Had a simiar fault with my fiesta. Turned out to be a failed plate in the battery which meant that the alternator was on full output constantly to keep the battery charged.
Jamie
H3lly
November 12, 2011, 10:37 am
As said get battery checked. Most motor factors will have a tester to do this. Also check for corrosion on the battery terminals.
