I'm just being paranoid here due to the large amount of problems my car has given me. It has been extremely well behaved this winter despite the severe cold and I don't want to ruin things now! Never having done this before myself I'm a little scared of doing it. Yesterday when filling up my washer fluid bottle I'd thought I'd check all my other levels as well to discover my oil level is right on the minimum mark so I need to top up. No idea how long it's been like that so I am a little scared of driving it now although I have no choice as I have to drive it everyday to work. Might pop down to Halfords to go buy some at lunch time today. Now what I am unsure about is will I get away with just topping it up not knowing what oil my garage put in or is mixing oils not a good idea? So is draining the oil totally and then putting in new a better idea?
On a side note which I should probably ask somewhere else I have a few minor problems with my electrics which I am suspecting a fuse has gone and maybe a loose wire. Probably will get it checked out in the next few weeks but as they are so minor I'm in no hurry.
1. When opening the door with my headlights on I'm no longer getting a warning sound.
2. The first time I put my car in reverse the reverse light doesn't appear to come on until I've moved a few feet. After that it comes on fine every time.
3. Occasionally the lights in the central console do not come on (heater lights). I give it a bash and it comes on. The heater itself is working fine.
4. Interior light when opening the door - this is no longer coming on for either driver or passenger doors. The switch is definitely in the correct position. Pressing the button in the door does turn the light on but if you then close the door and open it again the light fails to come on.
Any ideas? 1996 mk3 Fiesta by the way
