vonn
November 20, 2011, 10:17 am
My car is 7 weeks out of warranty! With only 16k on clock. And typical of my luck has developed a fault this morning.
The esp warning light is showing on the dash continuously.
Any ideas what this may mean or cost before booking it into main dealer? Is it a common fault?
fernsie
November 20, 2011, 1:57 pm
Found this online ...
[url="http://www.justanswer.com/uk-ford/2gtrc-hi-esp-system-fault-abs-light.html"]<< Original Site >>[/url]
[quote]Common faults with these are with brake light switches going faulty - so you could check that out..
Also - check the fuses relating to the systems in questions - a blown fuse will put the light on..
After that - there really isn't anything you can do on a DIY basis - you will need then to have the car connected to a suitable diagnostic machine..
That will scan the system - and will highlight the area of fault... usually an ABS sensor fault..and then you can have that replaced - or whatever the tool highlights.. - Most small garages have the equipment to do this test for you ...[/quote]
