mtc
November 28, 2011, 3:37 pm
[quote name='mondeo man' timestamp='1322343040' post='154125']
arh...just got the same problem..i asked on the mondeo club thingy...so is it an easy thing to do..even for some one who's isn't mechanical minded ?
yep, fairly easy.
First you need to remove the small plastic screw cover disc from the inner door mirror cover and then remove the screw and the plastic cover. Next remove the similar cover disc from inside the inner door realease handle and remove the screw (torx - these are star shaped screw heads requiring torx bits) and the inner door release handle cover. Next remove the inner door pull handle cover (the one you put your hand into to pull the door shut) this is done by placing a thin blade between the cover and door card and prising the cover inwards towards the door card. Underneath this cover will be 2 screws that need to be removed.
Next remove the 6 screws holding the door card to the door, 2 at the hinge side, 2 at the door lock side, and 2 underneath. Pull the door card away from the door at the bottom and lift up slghly to remove the card. Do not pull the card to far from the door as you will need to unplug the eletric window loom plug from the switch. Place the door card to one side.
Next remove the plastic grommet from the door lock face of the door, it's above the lock and in line with the outer door handle. Behind this grommet will be the outer door handle retaining screw, remove the screw (torx) then pull the outer door handle out and remove the back part of the handle that remains staionary along with the seal. Next slide the outer door handle back and pull out to remove.
Carefully peel back the inner door shield enough to access the inner part of the door handle and lock mechanism. Remove the electric plug from the lock, there is a catch on the door skin side of the plug that will need to be pressed in to release the plug. Remove the 2 screws holding the inner door handle in position (torx) and then the 3 screws holding the lock mechanism to the door. Slide the inner part of the door handle forwards to release the handle. The door lock and handle assy should now be free. Unclip the door pull outer cable from the door lock and then rotate the lock to allow the inner cable to be removed. The complete assy will now be free. Unclip the upper door handle assy from the lock and twist so that the metal rod can be detached from the lock.
To test the wiring there are 3 wires in the plug 2 yellow and 1 black, test between yellow and black and when the central locking is activated you should get 12v for abut 1/2 a second if not test between the other yellow and black (1 yellow is for locking - the other yellow is for double locking) If you get 12v then the wiring is ok. If you get a lock from a breakers then plug it into the loom before fitting and activate the central locking - you will see and hear if i's working. To test the lock put 12v across 2 of the 3pins (can't remember which ones but try all combinations and either it will work or not!)
Relacement is a reversal of the above.
Hope this helps
MTC
