hatz_87
November 26, 2011, 1:17 pm
Hi I need some help I have a 2000 ford Ka and can't find the serial number and i can't unlock the radio can you help me please?
delboy
November 26, 2011, 1:36 pm
c
hatz_87
November 26, 2011, 1:39 pm
[quote name='delboy' timestamp='1322336164' post='154069']
remove the radio and there is a number on there that you need to get the unlock code
what radio is fitted that may help ?
let us know
you can try this code 6743
Ford Code Entry Instructions
Once the unit has been turned on the display will show ' CODE - - - -'
Press preset [ 1 ] repeatedly until the first digit of the code appears on the LCD
Press preset [ 2 ] repeatedly for the second digit
Press preset [ 3 ] repeatedly for the third digit
Press preset [ 4 ] repeatedly for the forth digit
To enter the code press the [ 5 ] key to accept (in some cases you may need to press the [select] key instead).
The set should now operate.
If you are unable to enter a code, leave the radio powered up for 1 hour to reset.
If the display shows LOCK10, turn on the radio whilst holding down 6 you can then enter the code.
DO NOT KEEP TRYING THE CODE if it does not work as you might permanently lock the stereo.
what do you mean by repeatadely?
Rickprice21
December 6, 2011, 2:13 pm
I just want a code that works for free....
Serial number M017901
For ka
Some one please help!
delboy
December 7, 2011, 12:21 am
repeadidly mean press number 1 several times as it will go from 1 to 9 then move to next number etc
sounds like you should get someone to do it for you if you cannot understand simple instructions
Rickprice21
December 7, 2011, 1:24 am
Are you kidding me? I didn't say I didn't understand the instructions you douche! I said I wanted a code.
Maybe you shouldn't reply to forums if you can't read simple requests....
delboy
December 7, 2011, 12:58 pm
if you read my original post to you there is a code there for you to try & i added all the instructions on how to use the code & there is a link to where you can get a code for the radio.
do not insult those who are trying to be of help to you.
Unlock Radio
