mitch84
December 6, 2011, 4:30 am
Hi
Recently had my focus 1.6tdci in for a problem with the "service oil" message coming up in the display every time I turned the ignition on , I thought it might just need a reset but although this might of been the case as I've only had the car 2 weeks as before it was a Ford Direct owned car and had a service in September , Fords changed the oil and oil filter and kept it in so they could do a regen.
Im aware that this message could be caused by the DPF is that correct?
Anyway is there a way to tell when your car may need a regen?
which can be sorted by doing a steady 40 for so many miles.
Mitch
Nigel S
December 6, 2011, 5:53 am
Not owning a diesel I can only guess that your DPF needs new oil. If this is the case then get it sorted ASAP before you do major damage and cost yourself £1500 for a replacement DPF.
This is the great diesel rip off that started with the Euro4 cars in the mid 2000's.
mitch84
December 6, 2011, 6:04 am
[quote name='Nigel S' timestamp='1323172427' post='155433']
Hi
the problem has been fixed now , I think it was to do with the oil and regen processes. Just would like to know if others have had this message?
thanks
TDCiST
December 6, 2011, 6:06 am
I havent yet... but i'm expecting it... i bought the car after it doing 4500 miles in a year... needless to say, ive been doing a few 4th gear motorway journeys to make sure its clear! lol
mitch84
December 6, 2011, 6:17 am
[quote name='TDCiST' timestamp='1323173204' post='155437']
Well I hope it does'nt , what sort of speed are you doing in 4th , I might try a run next week.
TDCiST
December 6, 2011, 6:20 am
just 60-70... just keeping the revs up to get heat into the system... thats how the old FAP's and DPF's used to regen, wethere the new ones do i dont know...
mitch84
December 6, 2011, 6:22 am
[quote name='TDCiST' timestamp='1323174007' post='155444']
Do you do it for a certain amount of time say 20mins or so many miles?
thanks
TDCiST
December 6, 2011, 6:24 am
just a couple of junctions... So what, 5 miles, maybe not even that. A regen doesnt take that long if i remember correctly...
mitch84
December 6, 2011, 6:27 am
[quote name='TDCiST' timestamp='1323174257' post='155446']
Yeah i heard a regen was about 15 minutes , not to sure though ,I always thought theres ECU in the system so we dont have to do these regens ourselfs.
james_60
December 6, 2011, 6:29 am
Hi
If this is a stage V emissions compliant car it will not have a fluid tank for the dpf.
It will have a coated for life dpf
Are you familier with the Ford Etis website
Jamie
TDCiST
Maybe... i am new to DPF's. yet to do a lot of research, but im getting there lol!
TDCiST
December 6, 2011, 6:31 am
[quote name='james_60' timestamp='1323174584' post='155449']
Hi
Jamie
Does this mean it doesnt need to regen?? or will it still do it without the need for fluid??
james_60
December 6, 2011, 11:01 am
Hi
What it means is that there is no fluid tank
The Fluid is used to lower the temperature at which the soot is burnt off when a regen is being completed.
Fluid is refilled at the 37500 service iirc
Stage V Vehicles have a dpf that is coated in a special metal that makes burning off the soot easier.
Stage V is better imo
Jamie
