Full Version: 55 Diesel Van
dougdevos
I've got a 1998 55 diesel van that has an occasional starting problem. Sometimes the key start doesn't operate. I've changed the key switch, changed the starter motor, & wired the starter solenoid on a direct switch. When this switch is operated it turns the starter but the engine doesn't fire. Is there a security device in the ignition cicuit which disables the fuel cutoff solenoid & so stops the engine starting, even when the starter is operated directly?
mickmk6
yeh sounds like some thing i had with the key and the coding failing on it eventually got new barrel+key+coded=doorlocks to match for 100
dougdevos
[quote name='mickmk6' timestamp='1323820288' post='156405']
Thanks ha! guessed it would cost money!
Full Colour Version: 55 Diesel Van
