mitch84
December 7, 2011, 5:01 am
Hi
Im guessing climate control works pretty much the same threw out the focus range, Ive never understood something about the A/C when in auto mode , I have a titanium with climate control , when I select auto the a/c light is highlighted yellow which I guess is on as I have the satnav touchscreen display.
Now does this stay on all the time no matter what temperature I have set or does it turn on/off accordingly in the background despite always saying its on in the display?
thanks
December 7, 2011, 11:59 am
It maintains the temp set the aircon pumps dont cycle on and off they use vss pumps which regulate the refridgerant to prevent the pipes from freezing so still work below 4 degrees the climate control changes the hot and cold mixture to keep the temp at whatever u set it as so its always running
mitch84
December 8, 2011, 4:22 am
[quote name='artscot79' timestamp='1323280746' post='155649']
cheers, I do have the option to turn a/c off , perhaps its best to turn off in the cold weather anyway?
December 8, 2011, 5:16 am
It regulates to stop the pipes freezing so in the cold it helps to remove moisture the draw back is the vents get moist misting the window after u switch it off best advice is to have it max hot for at least ten mins to dry the vents out
Climate Control Mk2.5
