Wibbly
December 10, 2011, 4:30 pm
Is this possible?
The rubber cap at the back came off and moisture's got inside leading to fogging. I can dry that out, but there are some steaks (water marks) on the inside of the front plastic 'lens'. Can the 'lens' be removed and replaced safely?
December 12, 2011, 5:07 am
I believe you can remove the lens, you would be best removing the entire light assembly, and disconnecting all bulbs and removing them from the holders. The lens should be "clipped" in place along the outside edge, bare in mind you need to line it up with the grommit inside to prevent more water getting in - otherwise you could open a bigger can of worms!
Wibbly
December 12, 2011, 5:27 am
Thanks. Anyone here done it? Just wondering what the risk is of
1. Breaking the clips
2. Failing to get a seal on reassembly
Either would be quite expensive!
December 12, 2011, 7:24 am
Breaking the clips is possible but if you apply "gentle pressure" then you should be fine (as long as they appear seperatable!)
secondly, if you are only removing the lens, wiping down, then re-applying, if you dont move the seal then you shouldnt have a great deal of trouble, unless your going to apply the lens then keep wiggling it about!
PaulB1803
December 14, 2011, 7:27 am
Lmk how you get on with this as I seem to have greasy fingermarks inside both lenses. I'm sure nobody will notice but they are irritating me.
Preee
December 14, 2011, 8:43 am
I noticed the clips when i changed my bulbs, look fragile to me and I’d be worried about sealing them again, i guess if i was going to do it i would get the light inside and warm it up with a hair dryer, so they might not be so brittle and then i would use clear sealant around the edge when re fitting
