cougs
December 17, 2011, 11:12 am
hi all , , ,, , need to pick ur brains ,, , , , , got a 2002 mondeo tddi with brake problem , , ,, been on going for a few weeks now , ,, when pressing the brake i get a judder as if the ABS is coming on if you hit snow or ice if i realease and brake again its fine , , , , , replaced the master cylinder , ABS block , just replaces the brake fluid today and its still the same ???????
any ideas might stop me getting rid of it , starting to cost me on parts
fishpond 47
December 17, 2011, 1:19 pm
possiably a warped disc, OR even just a build up of rust on the inner part of the disc (the center's of the disc where the pads dont touch) causing the brake pads to judder
December 17, 2011, 1:20 pm
have the discs/pads been inspected?
cougs
December 17, 2011, 1:30 pm
not the discs , , ,, like i said it feels like the abs is coming on pedal goes hard then a judder , then if i lift off and press again its fine
TDCiST
December 17, 2011, 1:52 pm
sounds like warped discs to me
does the steering wheel wobble slightly too?
cougs
December 17, 2011, 2:01 pm
no wobble , no pulling to one side when braking , works fine one minute then next is as if i hit ice
pragmatix
December 17, 2011, 2:27 pm
Could be a cracked ABS ring
fishpond 47
December 18, 2011, 12:05 am
[i]'a build up of rust on the inner part of the disc (the center's of the disc where the pads dont touch)'[/i] this gives you the same feeling through the pedal, worth taking a look.
