Balraj
December 24, 2011, 4:59 pm
Hi guys,
I just discovered that the key for the wheel lock-nuts is broken for my 2008 Mondeo. I have a piece of paper with the key which has a "Key Code" on it and says that if I ever lose the key, I should take this card with the Key Code to a Ford dealer and they will order a new key for me. So I did that, and got told that this key can be ordered in any other country except where I am.. that's Australia.
Now my question is, does anyone know if I can order this key from Ford overseas? If yes, how?
People at Ford Australia have been less than helpful, and I don't want to have to cut the nuts out, yet I need a solution quick because I could get seriously stranded somewhere if I had a flat tyre.
Any ideas?
Regards
Balraj Singh
December 24, 2011, 5:07 pm
Hello and welcome,
If ford cant get you the key it may be cheaper to ask a local tyre centre to remove and replace the locking nuts with an aftermarket type.
you could always try these guys for the key - http://www.fordpartsuk.com
they deliver worldwide..
ONETrueSaturday
December 24, 2011, 6:12 pm
Well yeah, fastest solution, and maybe the only due to your location is to get them removed from a garage and get aftemarket ones fitted.
Ford locking nuts come from Germany, a company called McGard, and delivery to UK for mine was about a month if not longer!
December 28, 2011, 6:46 am
I had these same troubles. The only thing that you can do, is take your Ford to a dealer, and ask them to use their master keys on it, they can remove the locking nut for you and you can put a standard nut on, or aftermarkets...
I had to do this, as it was going to take 2 months to get the same key I wanted, and was going to cost triple the price of a new set of nuts...!
Preee
December 28, 2011, 7:01 am
I had the same problem with my old Astra , they charged me £80 to get them out
, now if i need new tyres i won't let them touch the locking nuts i do it myself and always copper grease them
December 28, 2011, 11:00 am
My Dealer took the nuts off me for beer money! I was impressed...
Danny87
January 4, 2012, 11:46 am
I ran into a similar problem when I lost (I know!) my locking wheel nut key for my old Punto. A little alloy and wheel shop across town sorted it out for me and charged me £40 all in with new nuts afterwards. The guy just hammered this socket with cones inside, presumably then once they've locked in place they grip as you turn it to remove the wheel locking nut. Quite smart and only took 20 minutes!
Dan
January 4, 2012, 12:04 pm
[quote name='Danny87' timestamp='1325699176' post='159398']
Dan
was it the sockets with the spiral flutes inside? never seen a socket with 'cones' inside, quite interested
January 5, 2012, 2:50 am
lol, its an idea that works on the old lock nuts, but the new ones are a lot more secure, they have the spin ring so that you cant do that!
January 5, 2012, 5:32 am
[quote name='jeebowhite' timestamp='1325753433' post='159483']
will a small chisel sort out that spinning ring? and a BFH
rojariggs
January 5, 2012, 5:46 am
Last time I had this happen, my local Kwik Fit hammered a slightly too small standard socket on to the bolt and got the bolt off. Took 2-3 minutes and they didn't charge me.
I replaced the missing bolt with second hand bolt of the same locking pattern as my remaining bolts.
Rog
Danny87
January 5, 2012, 6:33 am
Yeah that's true, they're a lot more secure now! The locking nuts on my Punto had 4 little recessed holes (where the key would actually engage) and a bit in the middle - which is where the socket (spiral flutes sounds more like it!) was able to grip and undo. I'm pretty sure I have McGard locking wheel nuts on my Fiesta, as far as I know it's stamped on the locking wheel nut key, and the design (and method of unlocking) is identical to my fathers Colt - which uses McGards.
Dan
