fishpond 47
December 30, 2011, 3:23 pm
As the title say's, when using the remote you can hear all the doors lock (except the drivers door)then unlock because the drivers door is'nt locking, what will be causing the drivers remote lock not to be working? , it locks/unlocks ok with the key, and when you use the key you can hear all the other locks working.
Mike
January 3, 2012, 3:50 am
Sounds like it could be a siezed piston... does the door lock if you use the old key in hole method?
Secondly, if you disconnect the battery and then try to lock the driver door, does it work?
Finally, its probably going to do good with a dose of WD40, have you given this a go?
