J.R.
January 8, 2012, 9:44 am
Hi all,I need your advice please....
I've just had my rear shocks & springs replaced on my MkIII Mondeo at my local garage. After collecting it I noticed an annoying noise from what appears to be the rear left shock (this noise was not there before and I only replaced the springs as they were badly corroded). It's almost like a knocking noise especially when driving on a bumpy road. I took it back to the garage where they checked everything and said it could be the anti-roll bar rubber bushes or the drop links. I made arrangements to take the car back next week but thought sod it, I'll change the bushes & drop links myself which I've done but the noise is still there.
Any suggestions / advice on what I should look at next?
Thanks!!
btmaldon
January 8, 2012, 10:30 am
Sounds like the top mount has worn and therefore has some play in it which will give you the knocking noise.
pragmatix
January 8, 2012, 10:32 am
Have you checked the exhaust, thats what the knocking was on mine
J.R.
January 8, 2012, 10:47 am
[quote name='btmaldon' timestamp='1326040225' post='160109']
I'll look at that next...it does sound like the noise is coming from the top of the shock. Thanks for your help.
TDCiST
January 8, 2012, 10:48 am
agreed... by the sounds of it youve done everything else lol!
J.R.
January 8, 2012, 10:50 am
[quote name='pragmatix' timestamp='1326040320' post='160111']
Yep, checked the exhaust, handbrake cables etc - no problems. Thanks anyway!
J.R.
January 13, 2012, 1:11 pm
Thanks for all your suggestions...turns out it was the top mount which was causing the noise. All nice and quiet now! :-D
btmaldon
January 13, 2012, 2:01 pm
Glad its sorted, and thanks for coming back with an update
jj999
August 7, 2012, 8:18 pm
I too have a knocking noise which i suspect is the same problem, i'm assuming by the top mount , that this is the shock absober but how can i tell and what other places should i check
