Antifaith
January 9, 2012, 3:55 am
I've replaced most of the components on my Focus 1.6 TDci 2005 now (dpf,egr,air filter,fuel filter, eolys oil, oil feeder pipe, oil pickup pipe and turbo) and my new turbo has now started whistling as well as giving me a fun intermittent boost leaving me bouncing along the motorway like a kangaroo - which to me is a good indication it's on it's way out again, after only 4 weeks - since I've spent around £1600 on car parts and had many stress filled weekends fixing this heap - there is no way I'm paying for another turbo
It'll definitely be because of carbon contamination and after a quick search I've found this chemical cleaning kit
http://www.dieselturbocleaner.co.uk/ford-innotec-diesel-engine-turbo-cleaning-kit-8-p.asp
has anyone had any previous experience with these kits? I've read on a VW TDi forum that you can use an oven cleaner for similar effects but I wouldn't feel great putting Mr Muscle in my turbo if I'm honest
alz
January 10, 2012, 10:47 am
Hi, have you had any fault codes as this could be a sensor fault.
Antifaith
January 10, 2012, 11:24 am
Only P0100 and P0101 which are pending codes apparently - the turbo is caked up and whistling though, and I can hear the blades scraping on the housing
pragmatix
January 10, 2012, 12:52 pm
Did you clean out the Intercooler, before fitting a new turbo, its often forgotten and if not cleaned will make the turbo fail very quickly
salsheikh
January 10, 2012, 2:22 pm
[quote name='Antifaith' timestamp='1326102901' post='160251']
i know that Nick uses the innotec diesel turbo cleaner, he owns and runs R-Tech in Hinckley. It'll be worthwhile giving him a visit mate. He remaps and modifies cars as his business and should be able to help you out.
Antifaith
January 11, 2012, 2:41 am
No I didn't clean the intercooler as I wasn't aware you had to? I'll clean it tonight - see what we get out of the other end
I doubt the car would make it to hinkley and if it did, it's bound to cause more damage than good by driving it - I might give him a ring though as the kit has just arrived this morning
alz
January 11, 2012, 2:54 am
the codes that you have are Generic codes,
P0100 Mass or Volume Air Flow Circuit Malfunction
P0101 Mass or Volume Air Flow Circuit Range/Performance Problem
have you checked the Manifold Absolute Pressure sensor (MAP)
Antifaith
January 11, 2012, 4:25 am
Yeah, it was a little caked up, so I cleaned it with some strong cleaner - could this be causing the bunny hopping?
tbh I'm just going to get it running as smooth as possible so I can sell it now - I've had enough
January 11, 2012, 6:40 am
most likely will have some part to play in the bunny hop, I would say quite likely in fact. due to the fact that if the air intake isnt smooth and cionsistent to supply the engine, then any variations and deviation from the fuel quality will cause your engine to labour as the combustion process will fail to complete efficiently...
p.s. antifaith, are you looking at getting a new Ford or are you looking to move away from it?
Antifaith
January 11, 2012, 6:51 am
I'd like to stay with them, but get one with a ford engine instead of a Peugeot one plonked into a ford chassis - Peugeot are
Do you think if I gave the MAP a quick spray with the turbo cleaner it'd help? or just burn the thing into oblivion?
Obv I'd get a new one, but there isn't much point spending the £80 if I know the turbo's knackered and I want rid
January 11, 2012, 8:08 am
Not sure the turbo cleaner will help the MAP, could just clog up even further. Its going to be better getting it replaced... besides, would it be better for you to spend a few quid now, and get more in return, or are you at the point you want to cover up the bruises with a bit of makeup and sell it on as soon as possible?
Antifaith
January 11, 2012, 8:55 am
sell it on asap tbh, especially with the turbo playing silly buggers again - I swear this car has aged me at least five years with all the stress lol
It's got fairly high mileage so I'm not going to get an amazing amount for it anyway - If I got what I paid for it I'd be happy really - just have to forget about the £1600 I've thrown at it trying to fix it
Am I right in thinking the MAP sensor is the tiny little metal wire in the pipe leading to the air filter? I'm thinking as the cleaner is designed to kill carbon deposits, it may help slightly, I might just give it a quick blow to see if it can shake anything without melting it - I'm guessing the chemicals are pretty strong and if it does clean it - it may help
Fingers and toes crossed that it helps the turbo out enough to stop it whistling at all the girls....and....guys....and...cats.....and....well....everyone lol
alz
January 11, 2012, 8:59 am
The MAP sensor, as a variable resister in it, controlled by pressure in the intake manifold which sends signals to the ecu to determine fuel to load on the engine, cleaning it will only clear the pressure intake, you will also need to check the sensor with meter for resistance.
Antifaith
January 11, 2012, 9:44 am
awesome thanks for the detailed reply mate - I'll let you know how the cleaning goes tonight - I'll maybe have to pop down the the scrappy and see if I can pick up a spare
young fez
January 11, 2012, 10:20 am
hi mate i have the same problem turbo 5 months old on a 1.6 tdci 06 plate whistling right bad cant afford to replace the turbo so when it does blow again i am fully comp on my insurance. hope you get it sorted mate.
Antifaith
January 11, 2012, 10:38 am
If this cleaner is any good I'll let you know mate - could save you having to claim
Antifaith
January 12, 2012, 7:11 am
Seems to have done the job - the turbo was caked in about 1-2mm of carbon everywhere - I put the cardboard seal over it - secured in place with the big clip and a bit of ducktape - filled it up and waited about 50 minutes, whilst adjusting the little lever (can't remember what it's called) on the front of the turbo every ten or so
Then cleaned all the gunky crap out with the second can and the turbo looks nice and shiny again - there is still some residue left over but not anything major
Whilst I was waiting for the first can to do its magic, I added the 3rd bottle to the fuel filter - I haven't had a chance to start the car up yet as it was 3am by the time I finished and didn't want to wake the neighbours - but it has to give some improvement with all the crap its cleaned off- I thoroughly checked the condition of the turbo and the blades aren't moving a great deal and generally look in good working order, just hoping I can start it tonight - fuel filters can be such a pain lol
The DPF looks like a black hole , considering that was new on 2 months ago it's definitely not looking good
Could the MAP sensor cause all this? Or is it just the engine? I know they get really crappy after a while and can need replacing
*love the new site - looks swanky
January 12, 2012, 7:59 am
Probably just the cack that builds up from fuel quality, and what slips through the fuel filter. By the sounds of it the cleaner was a good investiment!
as for the fuel filter, well those things are well and truely abused, so it doesnt suprise me that it was in a disgusting state (no fuel looks clean when it comes out the pumps!)
Hopefully the car started well for you today? did you find any improvement on noise / performance of the turbo?
Antifaith
January 13, 2012, 4:42 am
lol, well I had a bit of trouble last night - tried turning the engine over and all I got was a *clunk* and the front lights flashing on and off - a massive uh oh moment.....
Disconnected the battery incase the immobiliser had been triggered....no luck - checked the fuel filter, and topped it up again - no luck - voltage on the battery was down to about 12.2, so tried a jump start....*clunk* again no luck - disconnected the dpf and air filter from the turbo incase there was built up pressure from the liquid.....*clunk* put it back together, thinking I'd proper messed up the engine, or that the starter motor had gone....
Though I'd give it a bump start in case there was just something stuck, pushing it down the road for ten minutes or so....same *clunk* and flash - nightmare!
Pushed it back onto the drive thinking I'd have the scrap the bugger - just by chance I gave it one more turn just to check, and LIFE! lol
Took it for a drive and it's not amazing, the turbo has stopped whistling, which is nice, but when you hit around 40mph there is the distinct sound of the blades scratching against something - what I'm thinking is there is still a little carbon left, and the cleaner has removed any lubrication there was around the blades - resulting in a fairly nasty scraping sound - I'm going to pop some WD40 in tonight after work just to help it rotate a bit smoother - do you think this would help?
No idea why it would'nt start - I didn't turn the car over after putting the cleaner into the fuel filter and left it to sit overnight - but the cleaner wouldn't do anything unless there was heat in the engine - so I can't imagine this would cause any issues really
Hopefully the WD40 will help with the scraping sound and I can flog it within a couple of weeks - what do you guys think?
January 13, 2012, 6:28 am
Sounds like a plan, you might be better with something a bit more oily, or silicon based in the turbo in the interim, hopefully something like that will keep the squeaks at bay for longer!
Sounds a bit worrying that it was dead as a door knob though, but glad that it just wanted to give you a heart attack - better than a dead motor anyday! lol
Antifaith
January 13, 2012, 6:36 am
Good point.. I'd recommend the kit to anyone trying to get a little more time out of their turbo though - or anyone getting fed up of sounding like a fire engine wherever they go - I'll see what lubes I can find online today and let you guys know if they work at all.
I know right? really weird that it just died, thought I'd seized the engine, or hydro blocked it, or the started motor had packed in - a million things running through my head really - I'm just starting to consider what car to get next really - I've got around a £2.5k budget providing I can flog this for a good price - any recommendations?? I definitely don't want anything with a DPF though lol
January 13, 2012, 8:21 am
Buy a cee'd if you come away from Ford
lol
as for the the following:
[Quote]
[/Quote]
Are we still talking about the car?
Genuine recommendations, either another Focus (not sure you will get the likes of yours for that price though), otherwise, if your looking for the same size, how about an older Astra / Vectra? if Vauxhall arent to your taste, maybe the Mazda 5 or similar series? Otherwise if you can find it, I would say (genuinely) take the Cee'd out for a test drive - even if you dont plan on buying it - you can see how it handles and feels
lol - it is a good car though
salsheikh
January 13, 2012, 2:06 pm
the not starting issues can be a dodgy earth lead - this happened to me before. it was raining heavy and i had just finished shopping in asda and the car wouldnt start. so i went to customer services and asked for help and tried the car again and it fired up straightaway. then a few days later it happened again but this time me and my brother tried to jump start it but nothing. the jump leads were connected to the battery and it wouldnt turn over. i called the RAC out and the chap connected the earth to the engine and it started. he did advise to always jump start the car using an earthing point. we found the dodgy connection, just ONE lead was loose but this caused the problem.
Antifaith
January 16, 2012, 3:24 am
[quote name='jeebowhite' timestamp='1326464492' post='161063']
lol - yeah I got some high performance silicon based lube from halfords, used for high performance machinery operating up to 245 C and high speeds - I couldn't be bothered to take off the DPF again over the weekend, that clip is a pain in the wotsits, but will have to do it on some evening this week after work, especially before it starts snowing, as the thought of doing it is getting more and more depressing by the minute in this weather
Yeah, I've been looking at that kia, trying to find it for a reasonable price on finance though - I know Seat are doing the Ibiza's for around £200 a month atm but with a 10,000 mile mileage limit, it isn't viable for me - I was thinking of getting the same car as I know the engine inside out now, I'd know what to watch for lol - still a bit of a risk though, and I'm not sure I'll ever truly trust ford again - keep your eyes out for any good deals bro lol
I'll let you know if the lube helps hide the screach/scrape/soul destroying sound
January 16, 2012, 8:41 am
lol, good luck with the lube though! as for the cars, yeah the problem is if you get a lease sorta deal where you get the mileage, its much better to get a finance based option than a lease variant...
I will keep an eye out for any sort of Ibiza - Focus sized cars though and let you know.
Antifaith
January 16, 2012, 11:58 am
sweet, nice one mate
Antifaith
January 23, 2012, 10:07 am
Yeah quick update - put in the silicon based lubricant and it's squealing like a piggie - sounds like its about to explode - so it looks like I'm going to have to put the old turbo back on
to be honest I think the engine is just nackered - before I was putting the lube in I was looking at the exhaust end of the turbo, and it was caked in carbon again - after like a 10 minute test drive
I doubt I'll ever be rid of this heap at the rate it's deteriorating
Barry_
January 24, 2012, 3:25 am
What about a replacement engine or is that not worth the hassle??
At the rate your going you will be more qualified than the chaps at the ford garages LOL
Antifaith
January 24, 2012, 9:37 am
Don't think it's worth the money or the hassle any more, I'm trying to get a new turbo under the warranty supplied when I bought it but doubt they'll cover it - figure it's worth a go though
I know right lol stupid considering I invested a couple of grand so I wouldn't buy a crock - now Im about £4k down with a car I probably won't be able to sell - the stress is enormous
I'm fully comp as well but I don't think it's worth raising my premium just so I can sell a car really
Ugh ...what to do?! wish I could scrap it for a couple of grand - I might try and use it as a deposit on a new car - this is the last thing I need right now really - especially when I'm trying to save for a mortgage!
January 25, 2012, 7:21 am
I would say stick it to the dealers. If you cant get rid of it and you want a quick sale, clean the sod up - take it in and get a deal done. they will look around the outside, check the cars apeparance and offer you a price - get a handshake on it and get rid that way, dealers ask less questions than private - granted you may make a loss, but a small loss is better than a total loss...
Look at it this way, my Focus was fecked, the DPF was on its last legs, there was a bit of damage here and there, there was a few scratches, and chips filled in with a set from halfords. the MPG was shocking, the thing was just one problem after another - the dealer paid more than the dealer listed price - he didnt take the time to look at it - opened his book, said I will give you this - jobs a good un. I would not have got that on a private sale...
Antifaith
January 25, 2012, 11:27 am
like a main dealer, or a small biz on the side of the road?
Antifaith
January 30, 2012, 3:09 am
Ok quick update - had a good look over the car on Sat, turned the engine on while looking at the engine - the crippling squeaks and rattles weren't coming from the turbo - and because it was cold I could see some heat coming from the back of the engine - turns out the chemical cleaning kit had made it's way up into the egr and loosened it - the rattling was the egr flapping about - so all I had to do was nip it up a bit and all was good to go - the turbo is still whistling slightly but I should be able to sell it fairly easily now - finally a bit of luck!
January 30, 2012, 8:09 am
Good man! glad to see that you have had a bit of positive feedback! surprised that it worked its way into the EGR and wiggled it out!
Antifaith
January 30, 2012, 10:59 am
I know, pretty odd right? I checked out a kio rio yesterday as it's more in my price range than the cee'd - it's a smart looking car, going to go for a test drive next weekend - I liked it apart from the fact I hit my head on the way in lol - also been looking at vw polos as they are doing a years free insurance with them which is cool - so hopefully I can shift this heap and get on to something that will be kinder to me aha
January 31, 2012, 9:08 am
glad to see I may have swayed you a little
lol, and the Cee'd's you can get a good price on, as far as quality is concerned, you can safely assume that the quality of the Rio against the Cee'd is like the KA against the Focus.
Whats tempting you to the rio? are you going the newest 88MPG rio? or are you going the older one? in which case what is selling it to you? the drive? the warranty? or the price?
Antifaith
February 1, 2012, 7:05 am
[quote name='jeebowhite' timestamp='1328022507' post='164118']
It can't be that much difference surely? lol - I'd be going for the newest model - didn't know it did 88mpg though - mainly the warranty as I know i'll never have to worry about a car falling to bits again lol - for the price I'd ideally like to be paying £150 a month - which I know I'll get with the rio with a £2500 deposit
February 1, 2012, 8:03 am
In the feel of the car (in respect of presentation) I personally feel that it is a difference, but I just think that the rio is too small. 88mpg on the diesel variant, its seemingly a very good small 'family' car.
Warranty is fantastic though
Antifaith
March 6, 2012, 7:57 am
Sold my Focus!
Decided to get a cheap run around - picked up a Pug 206 with 26k on the clock for £1200 - this way if anything breaks, I've got cash left over to fix it lol
March 7, 2012, 6:50 am
are you glad to see the back of it?
You still got any thoughts of heading towards the koreans later, or would you return to the Blue?
Antifaith
March 7, 2012, 11:53 am
hell yeah I am - don't think I'll ever get a Ford again tbh - Hopefully I'll be driving this pug until I can afford an Audi - not sure I'll go with Kia just yet - think they need time to grow first - realise what they want to be rather than copying everyone else
March 8, 2012, 7:31 am
true, or till they stop looking over the shoulder of the hyundai design team! lol.
To be fair the likes of the new Kia Optima (potential rival to the Mondeo) its basically the Hyundai i40.
I think they deserve a chance!
