[b]WARNING - This is not an approved DIY guide or procedure, just a record of what I did. I take no responsibility for its use by others.[/b]
Having carried out the usual chocking, jack and axle stand safety procedures etc, I removed the road wheels.
Next step was to disconnect the handbrake cable inner from the caliper lever. This was very easily achieved using a Quik-Grip clamp using a couple of convenient ledges on the back of the caliper and lever arm. Simply ratchet the clamp up until there is sufficient slack to pull the inner brake cable nipple out of the lever slot. I did this with my fingers, but it would be easy to attach a Mole Grip to the nipple if you needed to pull the cable.
Next I removed the 2 Caliper Slide Bolts using a 13mm ring spanner and a 15mm open ended spanner to counter-hold the slide mechanism. The main caliper assembly can then be lifted off the caliper bracket and the old brake pads removed by hand.
The pads are held in position on the caliper bracket by 2 spring steel clips on each wheel. Contrary to what I had read the clips are all identical and not 2 rubber covered. They were removed by hand and cleaned up easily with a drop of solvent to their original shiny condition with no corrosion evident, so there was no need to renew them, simply replace with a touch of Coppaslip grease where the pads contact the spring channels.
The face of the piston has 2 diametrically opposed key slots. I had invested in the Laser Ford Brake Wind-back Kit available on Amazon for about £20, but the bespoke S-Max key in the kit has 4 pins so would not fit! Fortunately the pins are a press fit so I was able to push 2 pins out in the vice after which the 2 pin key fitted the piston face perfectly. Winding back the piston with the tool was achieved very easily without fuss or damage to the seals and I can confirm that both pistons need to be rotated [b]CLOCKWISE[/b] to wind back.
Cleaning and reassembly of the caliper was then the same as for any brake job using the new caliper slide bolts with pre-applied sealant supplied with the new pads.
Once the new pads and caliper were refitted the handbrake lever was again ratcheted up until the cable inner nipple would fit into the lever - again just fingers required, then wheels back on, pump brake to take up slack, road test - job done!
All in all a very simple and satifying DIY job achieved withot swearing, damage or injury (for a change). I don't think that would have been the case had I not used the wind-back tool though - essential for the likes of myself.
