They are supplied with their own loom (see fitting instructions diagram), as it is assumed the lights are being fitted to a vehicle which did not have fog lights previously. As I am merely replacing old lights, I have not used the loom and have simply plugged the lights into the existing plugs.
However, the lights have an additional pair of wires for the 'angel' LED's around their rim. Can I simply wire these into my half and full beam wiring so the 'angel' LED's turn on as soon as the main lights are enabled?
I am unsure about whether it is as simple as this, as the supplied loom has a number of relays and fuses built in. The rear of the lights state that the 'angel' LED's are 12v at 2w. Any advice from someone slightly more car-electrics savvy would be very much appreciated
