EViS
January 23, 2012, 10:33 am
I want to install some additional driving lights which will require their own power source and have their own fuse. The end of the wire from the lights has a half-open round ring crimp terminal. Where is the best place to connect this to the battery?
I did look for a little box with bolts and nuts which hold a number of live wires in place near to the battery, but cannot see this anywhere on my 2004 Ford Ranger mk2.
Preee
January 23, 2012, 10:41 am
You can take it to the battery but stick an inline fuse inbetween first.
EViS
January 23, 2012, 10:46 am
[color=#474747][font=sans-serif][size=3]I can't go right to the battery as the small ring crimp won't fit onto the battery terminal.[/size][/font][/color]
[color=#474747][font=sans-serif][size=3]The loom (supplied with the lights) already has a 15A inline fuse. Can I connect directly to the MAIN fuse (as there is a nut/bolt) underneath it holding 2 wires in place? Or any of the other high amp fuses right next to the battery?[/size][/font][/color]
EViS
January 23, 2012, 10:47 am
double post
Preee
January 23, 2012, 11:35 am
As long as it's already has an inline fuse you will be safe to pick any live you need
EViS
January 23, 2012, 1:48 pm
[quote name='Preee' timestamp='1327340133' post='162825']
[color=#000000][font=verdana, geneva, lucida,]But would there be a problem if I connected them after the MAIN fuse? i.e. the fuse might not be able to cope with more current draw through it.[/font][/color]
Preee
January 23, 2012, 1:57 pm
The worst that could happen is the fuse blows , your only talking of lights so there should not be a problem.
If your worried then change the conector on the wire to fit directly onto the Batt
EViS
January 23, 2012, 2:07 pm
Ok, thanks for the help and clearing up any doubts
