[color=#333333][font=arial, helvetica, clean, sans-serif][size=3]hey all, really confused with this one. any help would be great
bought this car end of november and it wouldn't start when i got it home.
its taken me 7 weeks to get it going with a new starter motor
when you start the car, theres an immediate metalic grinding noise coming from the drivers side off the engine.[/size][/font][/color]
[color=#333333][font=arial, helvetica, clean, sans-serif][size=3]its rather loud and embarrassing at lights etc[/size][/font][/color]
[color=#333333][font=arial, helvetica, clean, sans-serif][size=3]when stationary, if you turn the wheel left or right even just an inch and HOLD it in position (so the steering wheel isn't in the "relaxed" postion) the noise is dramatically reduced and almost gone completely and you can here the engine again - but if you let go of the steering wheel and let it return to its normal resting position, it starts immediately.[/size][/font][/color]
[color=#333333][font=arial, helvetica, clean, sans-serif][size=3]there is also a notch/clunk in the steering wheel when turning the wheel.[/size][/font][/color]
[color=#333333][font=arial, helvetica, clean, sans-serif][size=3]i've tried googling this for the past couple of days [/size][/font][/color]
[color=#333333][font=arial, helvetica, clean, sans-serif][size=3]the notching while turning the steering wheel is common by the looks of it but i haven't found a solution - some say could be steering rack, some say could be power steering pump[/size][/font][/color]
[color=#333333][font=arial, helvetica, clean, sans-serif][size=3]the engine grinding noise, i've not found online [/size][/font][/color]
[color=#333333][font=arial, helvetica, clean, sans-serif][size=3]there is plenty of results coming up saying that when you turn the steering wheel, a noise developes and goes when you stop turning wheel - mines opposite to that lol[/size][/font][/color]
[color=#333333][font=arial, helvetica, clean, sans-serif][size=3]the answers to that issue was check the fluid level.....my level is at the max line/just below max[/size][/font][/color]
BUT
there is a leak of PSF - i'm not sure where its coming from but its dripping onto the floor near drivers wheel - only when engine is on
i checked the fluid level last night and it was well below minimum, i topped it up to max and it made no difference to the noise.
[color=#333333][font=arial, helvetica, clean, sans-serif][size=3]what could this be? [/size][/font][/color]
[color=#333333][font=arial, helvetica, clean, sans-serif][size=3]im too skint to take it to a garage and don't want to get fleeced by having expensive things replaced. if i knew what it was, i would take it to the garage to get it sorted and tell him what it was, instead of him telling me an array of things it is with a look on his face, that makes me think i need to re-mortgage the house ! lol[/size][/font][/color]
[color=#333333][font=arial, helvetica, clean, sans-serif][size=3]thanks[/size][/font][/color]
