Full Version: Need Help With Radio Code Please
Sandra Petty
Hi!
I wonder if anyone could help me.
Our garage had to disconnect the battery when the car was in for repairs. I can not get the radio out to find the serial number and what comes up when I switch it on is:
HAL30June 03-3
SW3.20
CDSW01.09.02
BEZEL SW1.1
010902
can you tell me which one the serial number is so I can get the radio code?
any help is very much appreciated
Sandra
Preee
none of those numbers are your serial number , try holding 6 and 1 , i think it is , the code should begin with an M.
Please be aware no code's are given out on this forum
Hi Sandra,
we cant help you on this one, because the site no longer gives out codes, but i can tell you that the information reading on your stereo screen is not the serial number,
you must remove the stereo and find the serial on the side of it, in order to obtain the code.
Sandra Petty
thank you for your quick replies!
I will try again by pressing 1 and 6 and double check!
thanks again :-)
