Elwis
February 2, 2012, 2:58 pm
Hi everyone! Situation terrable. My Ford was running funny last two weeks, little lower power than should be, little probles when starting. Than it died. Got it back alive but only 2/3 of 4 cilinders working. Took it to Diagnostics, codes p0351 and p0352 came up. Changed all 4 coils and plugs, still no spark. Checked wires but found nothing faulty.
I have been looking for similar issues in internet, but it seems to be a common problem of Ford. Does anyone have any idea what else to look at??? Hope it`s not a PCM...
Any help appreciated!
btmaldon
February 2, 2012, 3:26 pm
When you say changed all 4 coils, do you mean coil packs? I thought you only had one. Or do you mean you changed the HT Leads and plugs?
If the latter is the case, it may be your coil pack has gone.
Elwis
February 3, 2012, 12:06 pm
Yes, changed plugs. Checked HT leads, seem to be ok, so didn`t change.
btmaldon
February 3, 2012, 1:15 pm
I would change the coil pack, however some after market ones may not communicate properly with the ECU. If you can try a proper Ford one. Do you know anybody with the same car. You could try swapping the coil packs over.
Codes P0351, P0352
